Yet another obstacle-puddle under steering gearbox - JeepForum.com
post #1 of 3 Old 05-16-2003, 05:40 PM Thread Starter
hfjeff
hfjeff's Avatar
Once again the forces of nature are working against me! 9 months ago I became the proud owner of a salvage yard steering gearbox for my 78 CJ7. Greasy and dirty, but that usually means not rusty. I recently attached my steering shaft and turned it by hand. Low and behold I return from work and open the garage door only to find a pool of fluid under the box. I checked my OEM manual and see that these seals are relaceable. I believe I found them at http://www.tellico4x4.com/steering/72upgb.htm under part # 8134568. Does anyone have a different source and part number from Napa or Advance Auto Parts or AutoZone maybe? It looks easy to change these.
hfjeff is offline
post #2 of 3 Old 05-17-2003, 01:39 PM
DJC
1979 CJ5
Easy being a Relative term.
It couldn't be a leaky hose connection, could it?
You might also consider trying some Lucas-Oil P/S Stop-Leak. It Actually works pretty well. I have been quite surprized.
Failing that, there is Steer & Gear (800) 253-4327.
Not sure on the P/N: but you might indeed check with NAPA, etc.
DJC is offline
post #3 of 3 Old 05-17-2003, 06:37 PM
fuzz401
1978 CJ7
the pit man arm seal is 2 seals a snap ring and 2 flat washers jeep part number is group 10.605 part number 8134568 jeep dealers might still have them in stock if they fit till 99 the kit comes with grease in it to the hardest thing is to get the pitman arm off will need snap ring pliers and sone type of pick to get the 2 seals out
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v...slideshow=true
http://photobucket.com/albums/v31/fu...slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Steering Gearbox opinions??? CJ7_Jim Jeep CJ Forum 8 03-26-2009 12:17 PM
Will a YJ steering gearbox fit a CJ? ChiefBrody Jeep CJ Forum 0 03-26-2009 11:27 AM
Manual steering gearbox rebuild? wwhitby Jeep CJ Forum 5 11-11-2005 03:11 AM
Steering Gearbox brace Fropleyqk Jeep CJ Forum 4 06-24-2005 08:15 PM
CJ7 power steering gearbox question rocketman_ace Jeep CJ Forum 9 06-05-2004 07:55 PM
