Yet Another Axle Swap Question - Page 2 - JeepForum.com
post #16 of 18 Old 10-23-2009, 05:20 AM Thread Starter
Jonesie
1981 CJ5
Originally Posted by foggybottombob View Post
Yeah the AMC carrier/gears will swap but you will have to do a gear setup. The carrier break for a dana 30 is 3.54 and down. So for 4.10's in a dana 30 you would need a series 4 carrier while the one you have is a series 3. The AMC 20 uses the same carrier for everything but the 2.73. So an AMC 20 carrier for 3.54 is the same as needed for 4.10. But when you put new gears in any housing you will have to re-do the setup.
Thanks, Bob. This is all VERY helpful.
One last question: What i fI want to just pull my 3.54 gears out of my NT axles and put them into WT axles? Is that a straight swap, or is there still setup that needs to be done. Would this be something I could do, or would it need to go out to a professional?
Thanks - David
Jonesie
1981 Jeep CJ5
Working on a 360 V8, T-176, D300 Swap
Jonesie is offline
post #17 of 18 Old 10-23-2009, 07:34 AM
Cjwho
1981 CJ7
I was looking at these same axels last week. I found that the 2.73 gears would not work for me so i decided to pass on this set.
Cjwho is offline
post #18 of 18 Old 10-23-2009, 07:37 AM
foggybottombob
You would still need to do a setup. You can find a writeup on how to setup gears in an AMC 20 on this forum. So you can read that and see if you think you can do it yourself.
foggybottombob is offline
possible axle swap question brian613 Jeep CJ Forum 12 05-03-2009 11:24 PM
axle swap question a2tripp Jeep CJ Forum 7 12-15-2008 07:01 AM
quick axle swap question FISHFINDER Jeep CJ Forum 14 10-15-2008 10:14 PM
CJ5 Axle Swap Question bbaxter51 Jeep CJ Forum 4 04-02-2007 09:02 PM
Axle swap question, waggy 44 into NT CJ Blthomas Jeep CJ Forum 7 09-01-2006 07:51 AM
