Yes, it's a CJ-8 watercraft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Yes, it's a CJ-8 watercraft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 07-02-2013, 10:35 AM   #1
John Strenk
John Strenk's Avatar
1976 CJ5
http://www.gizmag.com/watercar-panth...1bee9-90211229
Take a Jeep CJ-8, put a Honda Acura 3.7-liter V6 in the back to provide 305 hp, add a fiberglass hull, retracting wheels, and a jet boat drive and you've got the new Panther from WaterCar, which it claims is the world's fastest amphibious car. Capable of doing over 80 mph (127 km/h) on the road and 44 mph (70 km/h) on the water, the Panther is equipped with a long-travel off-road suspension that allows access to less user-friendly lakes. The appearance of the Panther takes after the Jeep CJ-8 Scrambler, with a stretched wheelbase that provides extra interior room.
What goes inside the hull and chassis includes a powerful powertrain that provides motive force both on land and water. The engine for the Panther is the latest-generation Acura 3.7-liter VTEC V-6 engine. An all-aluminum powerplant, the V-6 is equipped with single overhead camshaft cylinder heads and 24 valves. Both intake and exhaust valves are controlled by Acura's Variable valve Timing and lift Electronic Control (VTEC) system.
This 3.7-liter engine is a bored and stroked version of the Acura 3.5-liter engine. As this left little clearance between the cylinders, the cast-in iron cylinder liners of the 3.5 liter were replaced by high-silicon aluminum liners. This results in better cooling and tighter piston ring seals. The compact and efficient 3.7-liter engine produces 305 horsepower at 6,300 rpm with special emphasis on mid-range torque giving this VTEC a peak torque of 274 lb-ft (371 Nm) at 4,500 rpm.
The Panther uses WaterCar's own transfer case with Winter's Quick Change gears and components to transfer power between a model 091 VW Vanagon bus four-speed manual transaxle driving the rear wheels, and the H450 Panther Jet drive. WaterCar's transfer case is rated at 1,000 hp, so should have a long service life in the Panther. The H450 Panther Jet drive is rated to 500 hp input.
Enough tech specs – how does the Panther perform? On the road the Panther is capable of a maximum speed somewhere north of 80 mph (128 km/h). Acceleration times are not yet available, but with 305 hp (232 kW) driving a car weighing just under 3,000 lb (1,340 kg), it is reasonable to expect snappy, if not extreme, acceleration. The VTEC engine has a compression ratio of 11.1:1, and requires 91-octane premium gasoline to avoid detonation.
Entering the water can be done at speeds up to 15 mph (24 km/h) if there is no step higher than about six inches (15 cm) and the beach is sufficiently firm. Some spectacular entries and exits from the water appear on the video below. Once in the water, the pilot places the four-speed in neutral, pulls a knob to switch the transfer case over to jet drive, pushes a knob to hydraulically lift the wheels and tires out of the water, and start boating. The entire procedure takes less than 15 seconds.
Once in the water, the Panther is remarkably stable for a boat that is only 15 ft (4.6 m) in length. It leans a bit in tight turns, but makes the most of the low center of gravity resulting from having both automotive and marine drive systems. This also renders the Panther a bit reluctant to get out of the hole to planing speed, but the amphib appears to handle well at its top speed of nearly 45 mph (72 km/h).
John Strenk is online now   Reply With Quote Quick reply to this message
Unread 07-02-2013, 10:40 AM   #2
John Strenk
1976 CJ5
Oh Heck,
just go here:
http://www.gizmag.com/watercar-panth...99/pictures#35
Unread 07-02-2013, 10:41 AM   #3
lucas07770
I want one!
lucas07770 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 11:06 AM   #4
hp_lovecraft
1981 CJ5
Keep in mind that you would have to have the engine installed, and title it as a kit car. The rolling chassis is only $75,000, and I'd assume many of the parts needed to finish the project can be sourced much more cheaply for aftermarket Jeep websites.
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 11:34 AM   #5
only in a jeep cj
Originally Posted by lucas07770 View Post
I want one!
I'd rather have the blond in the second picture....
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 01:01 PM   #6
lucas07770
ill take both
Unread 07-02-2013, 01:05 PM   #7
Maddog
Why's there a 2x4 behind the rear wheel in the second picture
Maddog is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 02:52 PM   #8
John Strenk
1976 CJ5
I carry one in my CJ for a parking brake!!!
Unread 07-03-2013, 05:29 AM   #9
RWise
1981 CJ5
In my state it would require 2 tags, 1 for the street and 1 for the water!
In the pics you can see marine tags and IDs on some, looks like Arizona.
I luv it!
check these offering out! LUV the trike
http://www.gizmag.com/python-waterca...ormance/13323/
http://www.gizmag.com/manta-amphibio...concept/18018/
RWise is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 08:50 AM   #10
Manhattan
1981 CJ8
Buy one quick - before Chrysler sues them into *#$&ing oblivion. As soon as they see this thing, they're going to release the litigation version of the Kraken. GM had to spend tens of million$ to hold onto their grille in the H2. The Panther copies the 7-slat grille, body lines, windshield, cowl, doors, etc. Maybe they get away with some of it as a kit? But I bet the grille gets tweaked. It took companies like Omix and Crown years to get the license to produce that grille.
It is badass though. A solid color, some white wagons... yeah... it'd be fun
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 09:54 AM   #11
John Strenk
1976 CJ5
Yeah, it's the grill that makes the marque. hard to copyright a door shape. but a grill has instant identification.
Unread 07-03-2013, 11:21 AM   #12
Manhattan
1981 CJ8
The grille is the registered/protected design. The rest of the "vehicle" looking so much like a CJ would be considered aggravating factors - showing clear intent to copy, and benefit from the Jeep.
Unread 07-03-2013, 11:41 AM   #13
MoC
I would think with as much engineering and money that has gone in to those things, as well as the problems Hummer had, that they have covered themselves.
MoC is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 11:42 AM   #14
MoC
What if they are using a grill that is produced by a jeep licensed manafacture?
