Xfer Case Shifter/Linkage Making NOISE? Any FIX? - JeepForum.com
post #1 of 1 Old 05-16-2003, 11:13 PM Thread Starter
DJC
1979 CJ5
A while back, I noticed a rattle noise and it was pretty bad. I was concerned that something was broken or on its way to giving out.
I tracked it down to the Transfer-Case Shifter, or at least if I put a Finger on it, a little pressure, I could keep it from vibrating and there is no noise.
I put a Large Rubber-Band around the Handle/Shaft and around the Heater-Box outlet. That applied just enough tension to quiet it down (no noise) but it is Really not Fixed.
My guess is that the Teflon (or whatever they are) Washers in the Shifter are shot or missing. I Greased the linkage Fittings, etc, but that didn't make a difference.
What likely causes the vibration/noise and what needs to be Fixed? The Transfer-Case, Transmission and Driveshafts all seem to function. Is there likely a problem in the Xfer case or is it more likely just in the Shifter Linkage, etc?
DJC is offline
t-case shifter linkage scrappycj5 Jeep CJ Forum 2 03-25-2009 07:41 PM
Dana 300 XFER Case Fluid dres Jeep CJ Forum 2 05-03-2005 10:56 AM
Transfer case shifter linkage shaft replacement help go85cj7 Jeep CJ Forum 24 01-17-2004 09:07 PM
CJ-7 xfer case gumby Jeep CJ Forum 17 08-07-2003 12:39 AM
xfer case questions GRUB Jeep CJ Forum 7 05-02-2002 07:52 AM
