Quantcast X-Mas Delima, What should I buy? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > X-Mas Delima, What should I buy?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-16-2008, 10:28 AM   #1
tshuelsman
tshuelsman's Avatar
OK i have about 1500$ saved up and am looking to buy a couple items for my Jeep but im stuck between what to buy..
1. XRC Smittybilt Seats= $399.99 for both
2. 4.5 Rubicon Express= $1100 plus shocks..... wont have enough money yet for tires
3. Howell fuel injection kit = $1100
I can't decide what to do.
I can get the Seats and fuel injection or i can get just the lift and shocks.
I'd like to hear what you guys think.
I have the orginal seats and there falling apart. I have a 32/34 Weber carb that runs pretty good, haven't had any mechanical problems, just has problems on declines when wheeling. The Fuel injection would improve my power band and help with fuel economy, not that i care. I didn't buy my jeep for gas milage. The Rubicon Express lift speaks for itself.
I had a buddy tell me to get a cheaper lift and the fuel injection...
what do u think
WTB set of 285/75/16 or similar , PM if you have
0lllll0
2006 Rubicon LJ
JKS ACOS, Rock Krawler sway bar links, ARB Snorkel, XRC-10 Winch, Rampage rear tire carrier, Rugged Ridge HID Fogs, HID Headlight conversion
tshuelsman is offline   Reply With Quote
Old 12-16-2008, 10:49 AM   #2
j33pman
You could always do this for EFI - http://bustedjeep.com/projects/junkyardtbi.asp
then do the lift.
And salvage a set of Cavalier seats to replace your stockers.
Then save up for your tires.
Bill H. - 1984 CJ-7
258 W/ Weber DGV 32-36, T5, Twin Stick Dana 300, Custom SOA,
Dana 30/AMC 20 Locked 4.56's, 33" Swamper LTB's, York OBA,
Custom bumpers, Homemade Swaybar Disconnects, Nutter Bypass, Team Rush
http://www.schohariecountyjeepclub.com
j33pman is offline   Reply With Quote
Old 12-16-2008, 11:01 AM   #3
Slawth
Slawth's Avatar
1978 CJ5
If the jeep in your Av is the victim, it looks pretty capable. If it were me I'd go FI first and do the lift and tires together, later.
edit: I would not go with the Smittybuilt seats period... There are much better seats for close to that $.
The End
Slawth is offline   Reply With Quote
Old 12-16-2008, 11:06 AM   #4
Truck633
GO ONE MORE!!
Truck633's Avatar
Carbs are obsolete in any form, some run ok, but do whatever you have to to get Fuel Injection Period!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Originally Posted by schitzangiggles
It is no wonder we were the best and brightest, our toys weeded out the really stupid/unlucky one. That way there were less idiots to reproduce. Now since we have child proofed everything, we're being over run with Dee dee deees.
Truck633 is offline   Reply With Quote
Old 12-16-2008, 11:29 AM   #5
b_c
uhhh...i don't think "obsolete" is the right word.
...carbs are just not "preferred" for off-canter driving (i.e. rock crawling).
check out the "truck avenger" by holley...it works well.
...and cheaper than an efi swap.
b_c
Colorado JeepPeople
my 2008 jk build
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline   Reply With Quote
Old 12-16-2008, 12:27 PM   #6
tshuelsman
tshuelsman's Avatar
I've been looking around at the Howell FI and Quadratec has only 2 version for my jeep model.
They show the standard version and a version to meet California smog
Then 4wd.com shows three versions. A Cal. version and two versions with around a 60$ difference. There customer service didn't help me at all
i have a
1983
258 I-6
0lllll0
2006 Rubicon LJ
Old 12-16-2008, 01:36 PM   #7
Truck633
GO ONE MORE!!
Truck633's Avatar
obsolete most certainly is the correct word!!!! even your Holley Avenger will stall on a steep enough incline!! Carbs served a great purpose, but with todays FI technology, they are obsolete, I had the best luck with a motorcraft 2100 totally built, tapered floats, aftermarket float spring, and baffled bowl, it ran excellent, however next to even a throttle body injected equivilent engine, there is no comparison. we can agree to disagree...agreeably! In my humble opinon, FI is your best bet.
Tom
Old 12-16-2008, 01:41 PM   #8
b_c
agreed...
b_c
Colorado JeepPeople
my 2008 jk build
Old 12-16-2008, 01:56 PM   #9
CJ Chet
How about this. BDS makes a great lift (lifetime warranty) and alot cheaper! My BDS 4" lift is currently on it's SECOND Jeep and still going strong.
At that price you could get the lift AND the seats!
http://www.bds-suspension.com/kits/406H
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 TJ Sahara.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
Old 12-17-2008, 11:42 PM   #10
kyle_bob
1981 CJ7
get the lift!!
-lifes short drive topless...
kyle_bob is offline   Reply With Quote
Old 12-18-2008, 10:33 AM   #11
SuB8HaVeN
I second the BDS kit.
And I would not say that carburetors are obsolete. I run a more modern Weber on mine and it has been getting very respectable gas mileage lately, as good as or better than any newer 4.0L I6 I've seen get. I did some crawling for the first time about a month ago and it didn't miss a beat or stumble in the least bit. Let's just say I was seeing nothing but sky quite a few times, and it never even hesitated. Back when I had a small aluminum boat I used to back it down a causeway near the beach and it was about a 45 degree incline. It never hesitated pulling the trailer and boat in or out.
Modern carburetors make a world of difference. And I wouldn't trade the simplicity of my carburetor for any fuel injection kit in the world. If ever anything goes wrong I can take it off, rebuild it, or just slap another one on. I couldn't say the same for a fuel injection kit.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 12-18-2008, 11:48 AM   #12
xeroOTG
1975 CJ5
I would wait and keep an eye here, I am doing a hybrid bustedjeep TBI setup. It will definitely be less than Howell, and slightly more than the GM route, with more flexibility and configurability than both.
xeroOTG is offline   Reply With Quote
Old 12-18-2008, 01:31 PM   #13
sikdogg
Get the lift ($1100) and do a DIY Mopar MPI conversion (~$400)...
http://www.jeepforum.com/forum/f8/junkyard-mopar-mpi-writeup-294427/
sikdogg is offline   Reply With Quote
Glock Forum
