Wrecked CJ5 - Purchasing Help - Page 2 - JeepForum.com
post #16 of 30 Old 04-27-2011, 06:12 AM
george29223
1978 CJ5
right now scrap metal prices are high that jeep will sell for 350 scraped
george29223 is offline
post #17 of 30 Old 04-27-2011, 06:34 AM
roadhog304
1973 CJ5
if it were me i would turn around and run far, far away from that thing unless you can buy it for less than scrap price. The drag link loks to be heated up and bent to work with the crappy spring over, and lord knows what else is wrong with it. anybody who will do something butch like the wood blocks is highly likey to do alot of other stupid things that we have not even seen inthe pics. run away
roadhog304 is offline
post #18 of 30 Old 04-27-2011, 08:23 PM Thread Starter
ilikethemalot
Thanks to everyone for the help! I think I am going to wait a few weeks at least and then make him an offer if he can prove the engine runs, show me title is clear, and I can see that the frame is straight. If not, on to the next jeep!
Thanks again,
ilikethemalot
ilikethemalot is offline
post #19 of 30 Old 04-27-2011, 08:33 PM
my_304_cj7
1976 CJ7
You got $500 worth the parts there. I'd say if you can get it for $400-500 do it, if he can prove it to be running and titled.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #20 of 30 Old 04-27-2011, 08:37 PM
243
1978 FSJ Cherokee
I would not just pass, I would pass at full throttle!
Dave's 78 Build
243 is offline
post #21 of 30 Old 04-28-2011, 06:14 AM
guitarfreak6688
1979 CJ5
Restoring a 32 year old vehicle is bad enough, but restoring a 32 year old vehicle that was in an accident would be extremely difficult. Through my restore of my 79, I've had a hard enough time just figuring out what's missing and what goes where thanks to my wonderful PO...i know i had to rebuild/box the frame from the transmission back plus i swapped on a glass body from nose to tail. It was a ton of work!
I can't imagine just swapping some of those parts and having a running vehicle out of that one. Before you know it, you'll have a garage full of jeep parts just from trying to fix one problem and finding another!
Also as Ken said, if you can, you really want to drive it. I bought mine with a blown head gasket and never drove or heard it run. The rear brake lines were disconnected, the front driveshaft was bent, the rear driveshaft was redneck welded, the transfer case had a chipped gear, the transmission had parts coming out of it. After replacing the head gasket, I found out I have a cracked block and it has tons of blow by. Moral of the story...it's nice when you can drive it!
I'd pass and find one thats closer to being drivable.Good luck!
guitarfreak6688 is offline
post #22 of 30 Old 04-28-2011, 10:35 AM
LSUtiger
1980 CJ5
If you bought a $3000 jeep instead of that one it would save you $5000. I figure that if you put $2500 into that one it would still not be drivable.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #23 of 30 Old 04-28-2011, 10:40 AM
MoC
x2 on that
MoC is offline
post #24 of 30 Old 04-28-2011, 10:44 AM
mastercraftka
Rebuild? no way!!! part it out! If the engine runs I would give $500.
mastercraftka is offline
post #25 of 30 Old 01-25-2012, 06:29 PM
benjy58
1964 CJ5
First take a tape and measure the wheels from front to back from center of the front wheel to center of the rear wheel on each side if it's not the same there could be frame damage. All it looks like to me is a parts vehicle.
benjy58 is offline
post #26 of 30 Old 01-25-2012, 07:57 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
$2 to 250 dor a parts jeeps, or wear out the tires on your vehicile to get the He!! OUT OF THERE.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #27 of 30 Old 01-25-2012, 08:14 PM
BagusJeep
1981 CJ7
From the photos I would guess the frame is bent and it has been through quite a lot of truma. The propshaft joint may have popped due to the great lift having reduced the splined length that was in contact and the crash has been severe enough to flex the entire vehicle and hey presto it has come out.
This may have been the same time the body tub acquired the flex and those curves in the tub near the doors. That looks like a serious flex in the chassis.
If you got it home and stripped the body off you could have a closer look at the frame and mechanics but I suspect you will just end up scrapping it and selling the few salvageable parts.
The PO did not value the vehicle, hence the messy lift etc. Pre accident it would have not been worth much, after the accident scrap value.
Now, don't let me put you off, it is just that there are better Jeeps out there in scrapyards. I would be surprised if the yard owner thought it worth starting the engine for you.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #28 of 30 Old 01-25-2012, 08:27 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
So this thread is 8 months old. Did the OP end up buying it?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #29 of 30 Old 01-25-2012, 08:30 PM
MoC
Looking at his profile he has not been on in 3 months. By the looks of it he likely would have had a few questions by now if he bought it. Parts jeep all the way.
MoC is offline
post #30 of 30 Old 01-25-2012, 09:05 PM
BagusJeep
1981 CJ7
Drat, missed that this was an old thread. Hopefully he passed on that pile of junk.
cheap , cj5 , new buyer , wreck
Need Purchasing Advice aikenis Jeep CJ Forum 13 03-30-2011 04:54 AM
Need help purchasing a transmission bulletproofcj Jeep CJ Forum 7 04-23-2010 10:16 AM
Might be purchasing an 84 Scrambler Mateo94XJ Jeep CJ Forum 11 03-07-2005 09:41 PM
purchasing cj5..lift help supersly_jones Jeep CJ Forum 0 05-01-2004 05:02 PM
Purchasing the lift TrhlJpr Jeep CJ Forum 2 10-21-2001 09:40 PM
