Would you replace this leaf spring? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Would you replace this leaf spring?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4wG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread Yesterday, 05:02 PM   #1
JeepdaddyRC
1983 CJ5
Would you replace this front leaf spring? Studying threads suggests bending is not wise. I am trying to stay stock. I would appreciate your experiences and recommendations regarding stock ride height springs from Omix, Crown, SD Truck, or others. This is light CJ-5 (no top or extra equipment). Mostly road driven or easy trail giving kids rides. Rather have a softer ride than a harsh lift. Have read many positives on BDS and OME. Do they even make a stock (or 1" lift). PO runs 31x10.50 on stock rims. There are oversize shocks on the front. Appears PO must have run a big bumper, winch, etc. Not sure how PO bent spring and shackle. Thanks for helping a forum newbie.
JeepdaddyRC is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:08 PM   #2
JeepdaddyRC
1983 CJ5
Forgot to mention - sway bar linkage lower nut also gone on same side.
Unread Yesterday, 05:11 PM   #3
firegod33
1977 CJ5
Not only should that spring be replaced but it looks like time for a complete suspension overhaul. I don't know anything first hand about the available stock replacement springs but BDS and OME both have good reputations for small lifts. Companies like Alcan Spring and National Spring might also be an option. All 4 new springs from Alcan should be about $800 and can be made to your specs.
Earth first... We'll Jeep the other planets later.
firegod33 is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 05:59 PM   #4
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yes, along with the other springs, shackle hangers, bushings, etc....
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:37 PM   #5
jeepdaddy2000
1971 CJ5
If you have a spring or blacksmith shop locally, they can repair it.
Personally, I would opt for a mild lift (2.5" or less), not only would this give a touch more clearance, but the ride will probably be better due to the springs not bottoming on the bump stops.
You may also want to replace the dust boot on that tie rod end while you're in there....
jeepdaddy2000 is online now   Reply With Quote Quick reply to this message
Unread Today, 09:17 AM   #6
JeepdaddyRC
1983 CJ5
My original thought was to keep the stock ride height and choose from Omix-Ada or Crown 4 leaf (light duty) springs replacing OEM part # J5363229. However, I'm open to suggestions regarding a small lift if all springs need replacing. Fixing this CJ-5 up for my young son to drive. Don't want to raise the center of gravity too high for safety reasons. It has a 2.73 gear ratio, T-176 and 31x10.50. I don't think I can run much larger diameter tires on this set-up. It shudders on take off (that could be another problem) and don't need a lot of cleaance. However, if a small BDS lift will improve ride quality, I'm open to that. Suggestions and recommendations welcome.
Unread Today, 10:52 AM   #7
CJ7Kid
I have the same drivetrain/tire combo, and it's killing the clutch. That's why I'm changing to 3.54s or 3.73s this winter. If your clutch is shuddering, it's probably already shot. If the T176 had a lower 1st gear, I probably wouldn't bother, but its a pretty high 1st gear ratio at 3.52:1.
CJ7Kid is offline   Reply With Quote Quick reply to this message
Unread Today, 01:17 PM   #8
texasdave
texasdave's Avatar
1980 CJ7
You could also look at doing a Wrangler spring swap. Find a wrangler from 88-95. They use a wider spring and the height would be the same. People who have done this say it is a better ride. Just go to the top of the page and do a search for spring upgrades or Wrangler spring swap.
texasdave is offline   Reply With Quote Quick reply to this message
Unread Today, 02:39 PM   #9
firegod33
1977 CJ5
The chattering is the clutch trying to overcome an insanely high gear ratio (high gears+oversize tires). That is very hard on it and, as already mentioned, the damage may already be done. You're opening up a can of worms, here. That suspension is definitely not safe, as is, and needs overhauled.
Unread Today, 03:31 PM   #10
Partsmke
1987 YJ Wrangler
This is pretty common as it does make the CJ ride softer. You need the spring packs, new spring perches for your front shackles and wider spring plates for the front. The rear springs bolt in place of your CJ springs. Go after market new on the springs with a mild lift 1-2.5 inches. The YJ springs have larger bushings which also last longer, keep stock length shackles, new shock absorbers would be advised. The YJ Wranglers were first built as a 1987 model.
Used stock springs are a mistake. Check your frame for cracks and weld as needed.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread Today, 04:11 PM   #11
Matt1981CJ7
1981 CJ7
You don't need to the change the spring perches on the front of a CJ to use YJ springs.
The only mod that is necessary is the front shackle hangers need to be 1/2" wider and the eye needs to be about 1" further forward. You can buy the wider shackle hangers, with the eye already in the proper location, that use the same bolt holes as the factory hangers. You will also need wider shackles on the front, or modify the factory ones to work.
Here's my YJ spring conversion thread. All the info you need should be there, somewhere.
Hope this helps,
Matt
Unread Today, 04:18 PM   #12
CSP
I think that was meant to say shackle hangers, not spring perches.
CSP is offline   Reply With Quote Quick reply to this message
leaf springs
