Would someone please explain the difference between a suspension lift and a body lift - JeepForum.com
post #1 of 6 Old 09-19-2007, 10:24 PM Thread Starter
Giff
I have been doing lots of reading and am trying to keep the dumb questions to a minimum, but I have always used suspension components to lower a cars center of gravity.
Would someone explain difference between a suspension lift and a body lift and why would you want a body lift? The concept of a body lift is about as foreign to me as speaking Greek.
Thanks, Giff
Giff is offline
post #2 of 6 Old 09-19-2007, 10:43 PM
jeepskate
Most 'real' trucks (unlike cars and car-like SUV's) use body on frame construction rather than a unibody. So, the body & frame are two separate units that are bolted together with rubber or polyurethane isolating bushings in between. A body lift in simplest form is just a set of spacers (and longer bolts) that extend the gap between the two. It's just cheap clearance for larger tires and like everything else has it up & down sides and can be overdone. A suspension lift is basically just a set of 'taller' springs (longer coils in the case of a TJ, leaf springs with more arch in the case of a CJ or YJ) that raises the frame further up away from the axles creating more room for bigger tires. Plusses & minuses there as well as well as different quality of springs and spring rates which will effect ride, handling & flex.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 6 Old 09-19-2007, 10:43 PM
CJClyde
A body lift consists of blocks placed between the body and the frame where the body is bolted. A suspension lift usually is replacing the leaf springs with new ones to raise the frame and body. Both RAISE the center of gravity.
1984 CJ-7, 4" Trailmaster, 31's. Future plans include complete rebuild with SBC 350, Dana 44 front, Ford 9 inch rear, and SOA with highsteer.
CJClyde is offline
post #4 of 6 Old 09-19-2007, 10:44 PM
CJfreak
1975 CJ5
People use a body lift to give them more room for larger wheels. Suspension lifts are done for the same reason but generally require more parts and money. A 2" body lift may allow you to jump up a size in tire while keeping your center of gravity lower. The frame/motor/tranny weigh quite a few pounds and lifting it all up 4" or more will effect it's handling. Body lifts are much cheaper and have much less effect on handling. Body lifting more than a couple inches will probably pose some problems and look goofy. Having said that, a 4" suspension lift can be safe and comfortable even though the center of gravity has been raised.
'75 CJ5 w/304/T150/D20/D44's/3.07/33" Thornbirds/Glass Body...
CJfreak is offline
post #5 of 6 Old 09-19-2007, 10:52 PM Thread Starter
Giff
OK, I understand the difference now. I am 33, so I have really lived with unibody cars my entire life. The thought of body on frame didnt even occur to me.
Thanks
Giff is offline
post #6 of 6 Old 09-20-2007, 04:49 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Here is a list of ways you can lift a Jeep...
cb
http://www.certifiablejeep.com/topten/howtolift.php
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
SPRING OVER AXLE- roughly how much lift do you get?is it better then a 4" +body lift? jeepcj7 Jeep CJ Forum 12 05-02-2012 10:33 AM
Poll: Keep 35s and Body Lift or Get 33s and no Body Lift? _Kyle_ Jeep CJ Forum 8 12-24-2009 08:12 PM
Please explain the difference in these AMC 20 brake parts motiv8ya Jeep CJ Forum 0 11-15-2009 01:25 PM
Body lift vs. Suspension Lift jmreagan Jeep CJ Forum 4 02-10-2006 03:49 PM
Body lift or wait for suspension romans111 Jeep CJ Forum 7 12-29-2004 06:38 PM
