Would a new distributor cap really help? - JeepForum.com
post #1 of 16 Old 07-23-2010, 07:16 AM Thread Starter
Dudman5703
The other day I went through a puddle at like a measly 15-20mph. Engine cut off right away. I have had this a few times, but this seemed a bit to slow at the time because I didn't just go hog wild into a huge puddle, it was one tire kinda just skimming it.
My question was would a new Dizz cap really help stop this a little better? Or is there something else that I can do?
°llllll° Money well wasted
Dudman5703 is offline
post #2 of 16 Old 07-23-2010, 09:05 AM
NelsonATC
1980 CJ7
Had the same problem with the OE style cap. Went team rush and was able to eliminate the problem using that cap as well as other tips and tricks posted by JH and others. The upgrade cost me less than $80 using the recommended parts (but not the MSD stuff)
NelsonATC is offline
post #3 of 16 Old 07-23-2010, 09:14 AM
7ate9
1977 CJ5
I have the same problem with my CJ. I replaced the distrubutor cap and it still does it.
7ate9 is offline
post #4 of 16 Old 07-23-2010, 09:25 AM
82JeepCJ7
1982 CJ7
Time for some Sillycone.
82JeepCJ7 is offline
post #5 of 16 Old 07-23-2010, 09:27 AM Thread Starter
Dudman5703
$80 overall? thats alot of a dizz cap!
sillycone really work? I got extra...
xD
post #6 of 16 Old 07-23-2010, 09:32 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Part of the team rush upgrade advises to use dielectric grease to seal the top part of the cap and use the correct kind of sealant to seal the bottom part and/or adapter piece. The whole point is to keep out water. Keep in mind that silicone sealer usually emits acetic acid (the same stuff in vinegar) as it cures, so this could cause come corrosion on the brass parts. So I think the reccomendation is to use a sealant that does not give off acetic acid, especially if the vapors would be confined inside the cap. When I did mine, I use grease at the top but did not seal the bottom because I don't anticipate driving in water too much.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #7 of 16 Old 07-23-2010, 09:40 AM Thread Starter
Dudman5703
hmm... Do i just seal the whole thing from oblivion? Because I do want to be able to open it again, right? xD what about some RTV sealent around the whole thing, that should keep water out but If i needed to get it open I could pry it by hand or use a screw driver or something.
post #8 of 16 Old 07-23-2010, 10:20 AM
scrapman
How do you seal up a dizzy with silicone when it has a vacuum advance lever that needs to move sticking out of the bottom of it?
scrapman is offline
post #9 of 16 Old 07-23-2010, 10:39 AM Thread Starter
Dudman5703
I ment like the cap. just the top part, so that deosn't get water in it. Not the whole distributor.
post #10 of 16 Old 07-23-2010, 10:42 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
You don't use silicone, you use dielectric grease.
You put some around the edge where the cap mounts. Keeps water from getting inside.
If you have the large cap conversion, you do it to the bottom of the cap adapter, where it mounts to the distributor (you CAN use silicone for that) and use the grease for the cap-to-adapter surfaces.
For the OP, the short answer is, NO, simply changing to the large cap will not keep water out. Sealing the cap will, and if you're not ready for the larger cap, you can still seal the one you have.
Pacfanweb is offline
post #11 of 16 Old 07-23-2010, 10:50 AM Thread Starter
Dudman5703
Alright, thanks!
post #12 of 16 Old 07-23-2010, 10:51 AM
ioport51
1977 CJ5
Dielectric grease
dielectric grease will do an excelant job of sealing the cap and plug wires and it will not require a screw driver to remove things.
Your distributer and actually your whole ignition system on the 77 304 was made by presto light / Motor craft?? feel free to stop me, if I am mistaken. To do an upgrade to an Hei or MSD ignition/ distributer would probubly be the single most impressive thing you could do for the over all performance of your CJ for less than $250 and one afternoon. There seems to be a lot of tribal knowledge and urban legend that goes with this mod, you definatly need to do your home work on this one.
"here baby, hold my beer, I want to try something."
ioport51 is offline
post #13 of 16 Old 07-23-2010, 10:59 AM Thread Starter
Dudman5703
I thought thats how you were suppose to go at it with you rig though?
post #14 of 16 Old 07-23-2010, 02:44 PM
kakai81
I had this same problem with the dinkiest puddle at work. I would drive through it on my way into the parking lot. When i tried to start the jeep later, it would not want to start. And, when it did start, it would run like crap for miles. Upgrade to the bigger cap and rotor, it will help a lot. I put silicone on the bottom edge of the cap adaptor, where it meets the dizzy. I used silicone with low acid, as that was all I could find, and let it sit open for a couple of days. Then I put dielectric grease in the groove of the cap, where the adaptor fits into. I put it all together and I haven't had a single problem with water since.
kakai81 is offline
post #15 of 16 Old 01-08-2017, 04:38 AM
ToddPaul
1990 XJ Cherokee
They also make rubber boots that go around your dist. to keep moisture out. Check with the local boat shop, see what they have, and stay away from the sealants .
ToddPaul is offline
304 '75 Prestolite distributor vs 304 '78 distributor Dad03 Jeep CJ Forum 19 08-26-2009 07:50 AM
DUI distributor Jeepguy91 Jeep CJ Forum 16 05-02-2009 07:53 AM
amc 360-Distributor new or ? 2manytoys2 Jeep CJ Forum 27 03-11-2009 12:59 PM
New cam old distributor GPER Jeep CJ Forum 2 03-01-2009 07:02 PM
which distributor? marmaduke Jeep CJ Forum 6 09-08-2006 12:52 PM
