Would a 4" lift look goofy with 32's? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Would a 4" lift look goofy with 32's?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 11-05-2013, 08:18 AM   #16
rebelbowtie
Originally Posted by lucdog
No tire (radial) will be the same height with weight on it. If one were to jack up the vehicle until the tire is just touching the ground. Then take a measurement, do the same without the jack, I'll bet you would see a 1" difference at least.
Bill
Not to mention the width of the wheel and air pressure can make a huge difference. Here is my spare tire unmounted next to one on my vehicle (granted worn) look at the tire height difference!
rebelbowtie is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 08:20 AM   #17
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by danielbuck
very true Bill! A friend of mine and I put on a set of 4" springs on his old K5 blazer, the springs and almost everything were all original (took us weeks to get all the bolts removed!) Once we were done, the truck was actually about 6 inches higher than where it sat before, the old springs were so flat. The original front springs were actually worse than flat, they were bent the other way, haha!
A 4" rough country raised my full size Jimmy 5.5" in the front, 4.250" in the back. I then custom made a body lilt from the rear towards the front to level the body.
Bill
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 09:00 AM   #18
243
1978 FSJ Cherokee
Guys, I agree the loaded tire height dimension Matt provided may vary a little between his AT and my KM2 but its a start. I will check their website to see if the unloaded diameter is close.
243 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 09:31 AM   #19
lucdog
lucdog's Avatar
1980 CJ5
I don't think the loaded height makes a difference. The tire will be the same distance from the top of the tire to the body, isn't that what the concern is.
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 11-05-2013, 10:33 AM   #20
BHawkmeck
1983 CJ7
4" Skyjacker with 33"
BHawkmeck is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 12:46 PM   #21
243
1978 FSJ Cherokee
Bill,
BFG indicates the AT is 31.7" in diameter and the KM2 is 31.8", so I will say equal.
I will jack up the jeep so the sill is 22" above the concrete and that should give me a good visual of the 2.5" lift that Matt is running on my Jeep.
That will give me a known baseline even thought it's not stock.
I can take a few photos and raise it another .5" to simulate a 3" lift and 1.5" to simulate a 4" lift.
Matt,
I assume the dimension is 21" at the front of the rocker trim and the rear, I believe I have about 1.5" of rake on mine due to the front spring sag.
I could also throw on some air bags
Unread 11-05-2013, 01:02 PM   #22
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sheesh, Dave, you are really being precise about this decision....
Here's my exact measurements:
Ground to bottom of rocker trim in rear = 22-3/8"
Ground to bottom of rocker trim in front = 22-1/4"
So, I have about 1/8" of rake.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 11-05-2013, 06:08 PM   #23
243
1978 FSJ Cherokee
Matt,
Please check your tape measure and see if the hook on the end of the tape is loose, that could account for the 1/8" difference if it moved while you were measuring
Just kidding, don't go check
It's raining here and dark too, I will look at it maybe tomorrow if the rain lets up.
Unread 11-05-2013, 06:20 PM   #24
lucdog
lucdog's Avatar
1980 CJ5
Damn daylight savings time.
B
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 11-07-2013, 08:10 PM   #25
243
1978 FSJ Cherokee
You are not kidding, I had to race home while the sun was going down to take some pictures. Thanks to Matt, I have a baseline, in the first photo, the rear of the rocker is 22" above the concrete, the front is 20.5" and the top of the tires are 31.25" above the concrete, close enough for comparison.
Second picture is with the front raised to get the rocker level at 22" simulating a 2.5" lift and the third is raised front and rear to 23.5" simulating a 4" lift.
The last looks good to me and if it settled a bit it would still be fine, what do ya'll think?
Unread 11-07-2013, 08:59 PM   #26
Matt1981CJ7
1981 CJ7
Dave,
I think both look fantastic!
Here's what I scratched my noggin over when I was in your shoes:
1. Additional mods that the 4" requires
2. Ride quality: taller = rougher riding
3. Looks: taller = better looking
Ride quality and desire to keep the steering and driveline components stock won, over looks.
Matt
Unread 11-07-2013, 09:19 PM   #27
BagusJeep
BagusJeep's Avatar
1981 CJ7
Those springs are sure flat, I can see why you want to do the change.
The second one looks pretty good, enough clearance between body and tyre. It will feel like a whole new vehicle.
IMHO the 4" lift is only worth doing if you are going to increase the tyre size again. Otherwise you have the same clearance to the diff but all sorts of new challenges to make the 4" lift work.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 11-07-2013, 09:22 PM   #28
lucdog
lucdog's Avatar
1980 CJ5
If the rear is sitting at 22" now, adding 4" of lift would make it 26", not 23.5". Of the 2 CJ 7's I have, after the lift was installed they sat level. If this is the norm for spring lifts, it's going to raise the front to 26" as well. I would add another 1" for new springs, and who knows how long it takes for them to settle. I'm staying with my post of 2.5".
The Jeep does look good in the pictures Dave.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 11-07-2013, 09:52 PM   #29
243
1978 FSJ Cherokee
Bill, Matt has a 2.5" lift and his is sitting at 22", that is why I said 23.5" simulates a 4" lift, is my math wrong?
Unread 11-07-2013, 10:22 PM   #30
lucdog
lucdog's Avatar
1980 CJ5
I read it as yours was sitting at 22", at the rear. So my mistake I guess. Matt also has a hard top, so depending on when he took the measurements...
Wondering if you got in the Jeep while it was on the jacks.
I also don't think new springs would ride as well as the worn out springs currently on your Jeep. Mine with 3" springs doesn't ride as well as the DD with worn springs.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
