Would a 4" lift look goofy with 32's? - JeepForum.com
post #1 of 40 Old 11-03-2013, 12:49 PM Thread Starter
243
1978 FSJ Cherokee
After a spin around the neighborhood yesterday, I realized just how choppy the ride is with the old and sagging factory springs and how bad I want to have the lift on before I start driving the CJ to work.
In my mind I was thinking 2.5" would be plenty and started searching for the best price on the Black Diamond YJ kit and read that Black Diamond used to be Warn but they are now owned by Superlift, and the springs may be Superlift.
Searching for other lifts, I see Rubicon Express has a decent deal with shocks and springs and it's offered in 2.5" and 4".
Considering the 2.5" lift is suggested for 31" tires, a 4" lift may be better with my 32's.
Just curious if a 4" lift would look balanced with 32's.
243 is offline
post #2 of 40 Old 11-03-2013, 12:50 PM
gmakra
It will look fine.
gmakra is offline
post #3 of 40 Old 11-03-2013, 01:50 PM
90lsturbo
my old 81 cj5 had a 4" on 32's and road/drove around fine
2006 dodge ram hemi -DD
1993 zj-sold
1981 cj5- traded
1984 cj7- the other mistress
#89 UJC
"Real men dont let their friends drive prius's"
90lsturbo is offline
post #4 of 40 Old 11-04-2013, 07:59 AM
benullman
1981 CJ7
32s with a 2.5" look better to me. I just think 4" with 33 and 2.5 with 31-32 looks more balanced. Neither of them look 'bad'. But you will notice the tire to wheel well size/distance/stance will look better with 2.5"
IMO!
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #5 of 40 Old 11-04-2013, 09:23 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Dave,
I went with a 2.5" YJ lift and 32"s because I didn't want to mess with modifying steering and driveline components, extending brake lines, t-case drops, etc, etc...
Personally, I think the combo provides the perfect balance between stock and stupid looking.
Matt
Matt1981CJ7 is online now
post #6 of 40 Old 11-04-2013, 09:31 AM
Spieg8
1984 CJ8
^^Agree with this^^
I actually ran 32s on stock suspension and they only rubbed a little on rear wheel well when wheeling. A 2.5" lift is about perfect for 32's.
Also recommend a YJ spring conversion as long as your doing a lift. A bit more work and a few more parts to buy, but well worth it. Smoother ride than any CJ spring you'll find. IMHO
Spieg8 is offline
post #7 of 40 Old 11-04-2013, 11:41 AM
Tigerjeep79
1979 CJ7
Check my avatar. 2 1/2" lift and 32s. I like this combo.
Tigerjeep79 is offline
post #8 of 40 Old 11-04-2013, 02:05 PM
lsukevinc
1979 CJ5
i have 32" MRT's on a 4" lift and it does not look bad, but a agree with the above, a 2.5" lift would be fine.
lsukevinc is offline
post #9 of 40 Old 11-04-2013, 02:27 PM
lucdog
lucdog's Avatar
1980 CJ5
I'd go with the 2.5" Dave.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #10 of 40 Old 11-04-2013, 05:16 PM
danielbuck
1946 CJ2
get a jack under the front and rear bumper and push the jeep up about 4 inches higher than stock. Stand back and have a look, see if you like the stance :-)
danielbuck is offline
post #11 of 40 Old 11-04-2013, 05:37 PM Thread Starter
243
1978 FSJ Cherokee
Good point Daniel.
Matt,
My springs are sagging so to get a baseline, please post your actual tire height and the height of your tub sill at the front and rear at each fender flare.
I can look at it at the height yours is sitting and then jack it up another 1.5" to simulate a 4" lift.
243 is offline
post #12 of 40 Old 11-05-2013, 04:35 AM
Matt1981CJ7
1981 CJ7
Dave,
Here you go.
I still don't understand how BFG gets away with selling 32" tires that only measure 30.5" brand new.
Matt
post #13 of 40 Old 11-05-2013, 07:07 AM
lucdog
lucdog's Avatar
1980 CJ5
Dave, remember your factory springs are sagging from when it left the factory. I wouldn't be a bit surprised if a 4" lift would raise your Jeep 5".
The only picture I have that's close to a 2.5" lift is this one.
This a 3" black diamond with full 33" tires.
As you can see the front fenders have been cut (because of rust) . The rear is untouched.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #14 of 40 Old 11-05-2013, 07:13 AM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Matt1981CJ7
Dave,
Here you go.
Matt
No tire (radial) will be the same height with weight on it. If one were to jack up the vehicle until the tire is just touching the ground. Then take a measurement, do the same without the jack, I'll bet you would see a 1" difference at least.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #15 of 40 Old 11-05-2013, 07:13 AM
danielbuck
1946 CJ2
very true Bill! A friend of mine and I put on a set of 4" springs on his old K5 blazer, the springs and almost everything were all original (took us weeks to get all the bolts removed!) Once we were done, the truck was actually about 6 inches higher than where it sat before, the old springs were so flat. The original front springs were actually worse than flat, they were bent the other way, haha!
