Wont turn right ! help? - JeepForum.com
post #1 of 16 Old 12-19-2006, 09:48 PM Thread Starter
jbeenz
Hi all,
im new here, i took delevery of my CJ4a last week, (are cj4's allowed here ), and im having some issues with the steering(RHD), it turns left perfectly, but just will not go right, the box appears to be working ok, if i force it right it will turn about 15 deg, then stop. i can force it but it springs back, im thinking its a problem with the bit that goes through the chassis? (had problems on landrovers in the past), whats the story with these on a jeep? all the steering rods are straight etc.
cheers
jed
jbeenz is offline
post #2 of 16 Old 12-19-2006, 11:05 PM Thread Starter
jbeenz
ok so ive seperated the ball joints(rod ends) and have found that the left swivell hub is limiting the left wheels turning angle,hmmmm, consulting hanes manual now.
jbeenz is offline
post #3 of 16 Old 12-20-2006, 09:20 AM
geojeeper
Good luck with the steering problem. Tell us more about your CJ-4a. Post some pictures if you can. I have heard of a prototype US CJ-4 that was never mass produced, but I'm not familiar with what was offered in other countries. Is it an AMC product or produced by someone like Mahindra etc.?
geojeeper is offline
post #4 of 16 Old 12-20-2006, 10:42 AM
kaibab
kaibab is offline
post #5 of 16 Old 12-20-2006, 11:08 AM
Indy
Indy's Avatar
Go the easy route. 3 left turns = 1 right
I'm the only gay eskimo.
Indy is offline
post #6 of 16 Old 12-20-2006, 12:27 PM Thread Starter
jbeenz
heheh, ive tried the powerslide method, requireing less lock, but its not really a practical solution
CJ4a is mahindra(India) made, its basicly a long wheel base version of the CJ3b, they all use dana axles, and the same gearbox/transfur as the USA built trucks, usually with an awfull indian built copy of a french 2.2 D, which was never going to be a happy situation!
in my case, rubish engine is removed, Holden(GM) 186ci 6cyl petrol is in, with a ford(UK) transit gearbox, attached to the stock transfur box. this all makes for quite a tough little truck.
unfortunatyly i dont have a descent camera to take pics with at the moment.
jbeenz is offline
post #7 of 16 Old 12-20-2006, 02:23 PM
kbtriumph
kbtriumph's Avatar
Is that a D44 front and is it open or closed knuckles?
If it is closed knuckle your steering problem could be related to the king pins or the closed knuckles.
Would love to see some pics. A friend of mine had a Mahindra CJ4 with the closed knuckle D44 in the front.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #8 of 16 Old 12-20-2006, 02:44 PM Thread Starter
jbeenz
i had thought it was a D30 from what i have read, but im not sure how to identify, on closer inspection its the same size as the rear, which is supposed to be a 44.
as for the knuckles, its got what my haynes manual bescribes as the early type, the ones with a "chrome ball" appearance and taper roller bearings top and bottom, current theory is that one of these bearings has locked up. does that make sense? (i was raised on landrovers....)
jbeenz is offline
post #9 of 16 Old 12-20-2006, 03:23 PM
kbtriumph
kbtriumph's Avatar
I would bet that it is the tapered bearings.
That is what I call a closed knuckle front.
'74 CJ6 Safari
'98 TJ DD
post #10 of 16 Old 12-20-2006, 03:46 PM Thread Starter
jbeenz
thanx mate,
how do i tell if the diffs are d44's?
jbeenz is offline
post #11 of 16 Old 12-20-2006, 04:33 PM
kbtriumph
kbtriumph's Avatar
If both of you axle covers are the same shape They should be D44s. I think that since your front is a closed knuckle it should be a D44.
D30 axles have an oval shaped cover. Here is a link for axle id.
'74 CJ6 Safari
'98 TJ DD
post #12 of 16 Old 12-20-2006, 05:00 PM Thread Starter
jbeenz
yup, 44's both ends. should handle all that im likley to throw at them ill try get some pics, it currently undergoing paintwork.
thanks for the help.
jbeenz is offline
post #13 of 16 Old 12-21-2006, 03:01 AM Thread Starter
jbeenz
arrragh! it got worse - wobbling
ok, so i oiled the tapper roller bearings on the left, and it improved a little, i will strip both hubs over the next week, but i needed it to tow somthing tonight, now it has developed a nast shake, like the speed wobbles or a spring at resonance in the steering ab about 40mph, to the point where i have to almost stop before it goes away, it shakes so bad that the truck starts rocking and wobbling uncontrolably, this is not a pleasent situation, could this be caused by not having the steering damper on, or have i developed a bigger problem? nothing appears to be loose.
mechanic told me last week to take the damper off if i wanted better lock, i will be keeping it on as it goes offroad alot.
thoughts? (damper is currently off)
im not driving it again till i think ive sorted this one out.
jbeenz is offline
post #14 of 16 Old 12-21-2006, 10:49 AM
Indy
Indy's Avatar
I had Dodge Warlock several years ago that had turning issues. It turned fine 1 way, but sucked the other. Looking at it from the outside I found that when turning 1 way, 1 of the wheels was tucked in fine, but the other was extrememly over turning. Kind of scary really and made parking a *****. I took it to 3 alignmet shops and had misc. work done including a section of frame replaced, and got the same results every time. The 4th alignment guy had it for 1/2 a day and told me that a PO had 1 of the steering pieces mounted backwards. He swapped it back around and problem was pretty well solved.
Indy is offline
post #15 of 16 Old 12-21-2006, 04:37 PM
kbtriumph
kbtriumph's Avatar
Have you checked the axle U-bolts?
'74 CJ6 Safari
'98 TJ DD
Cj7 Wont Turn Over!!! Help Plz cgi2099 Jeep CJ Forum 29 07-21-2014 09:58 AM
85 CJ7 will crank but wont turn over? HRW85CJ7 Jeep CJ Forum 18 09-29-2009 03:42 PM
74 cj5 401 will crank but wont turn over sherman401 Jeep CJ Forum 6 06-03-2009 04:47 PM
ok so i got it to turn over but it wont run bkeast17 Jeep CJ Forum 11 07-04-2006 07:41 PM
jeep wont turn over Fuzz21 Jeep CJ Forum 6 12-27-2005 04:53 PM
