won't stay put when parked on a hill - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > won't stay put when parked on a hill
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 11-14-2009, 01:32 AM   #1
meater
1981 CJ8
so,
when i park on a hill, i put my cj-8 in gear (usually 1st, but sometimes reverse). it will not stay put. rather it lurches and stops until on level ground. whats up here? somebody has suggested bad engine compression, and no real way to fix it. any ideas?
meater is offline   Reply With Quote Quick reply to this message
Unread 11-14-2009, 01:35 AM   #2
Coiz
1979 CJ7
Low compression is the cause of that but you need to remember that it is called a parking brake, not an emergency brake. In gear with the parking brake should be able to hold it and if you think back to your original driving classes, you will remember the reasoning behind turning your wheels towards the curb when parked on a hill.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 11-14-2009, 01:40 AM   #3
meater
1981 CJ8
is low compression a bad thing?
Unread 11-14-2009, 01:54 AM   #4
Coiz
1979 CJ7
It means the engine is getting tired. Buy, rent or barrow a compression tester and see what you've got. Be sure to pull all the spark plugs, throttle held wide open, crank the engine and record the 5th reading on the tester. Do this for every cylinder. Then add a tablespoon of oil to the cylinder and do it again. Fairly simple to run. Write everything down and let us know the results.
Mike
My build thread
Unread 11-14-2009, 02:07 AM   #5
meater
1981 CJ8
Unread 11-14-2009, 02:22 AM   #6
80cj
80cj's Avatar
1980 CJ5
The problem is compounded if you have high rearend gears and big tires. Put it in low range.
80cj is offline   Reply With Quote Quick reply to this message
Unread 11-14-2009, 06:48 AM   #7
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Yes it is a bad thing.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 11-14-2009, 10:05 AM   #8
IDK
Bad compression means that your motor is nearing the end of it's life and needs to be rebuilt or replaced. You will notice lack of power, and no downhill compression on steep hills. If you have a inline six it probably has close to 300,000 miles on it which is excellent for a motor, those things are hard to kill! It's probably just played out and could use a good rebuild!
IDK is offline   Reply With Quote Quick reply to this message
