Wont start - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wont start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 08-18-2014, 07:04 PM   #1
colledrolled
Wont start
81, CJ5, 258. It ran great when I parked it last.
I swapped out the dash and all the gauges. Gutted the heater unit. I put a valve cover on it. Installed a Heatercraft set up. Now it wont start.
Today I read allot of stuff about the Ignition module and decided to swap it out. I put a new coil in too. No change at all. It turns over strong and cranks the engine but it wont fire up. Im thinking a messed up some wiring but I have no idea what I could have done.
Any help?
colledrolled is offline   Reply With Quote
Unread 08-18-2014, 07:14 PM   #2
zillla
1975 CJ5
Pull a spark plug and check for spark..
Pull my finger
zillla is offline   Reply With Quote
Unread 08-18-2014, 07:21 PM   #3
colledrolled
How do I do that by myself?
Unread 08-18-2014, 07:22 PM   #4
zillla
1975 CJ5
Gonna need a helper or a remote start button. Turn the key on and check for volts at the coil
Pull my finger
Unread 08-18-2014, 07:29 PM   #5
delirious1
1982 CJ7
Turn on the ignition. Jumper from positive battery to starter solenoid where ignition wire goes. s terminal.
delirious1 is offline   Reply With Quote
Unread 08-18-2014, 07:42 PM   #6
colledrolled
I couldnt find any juice at the coil. Where should I be checking?
Unread 08-18-2014, 08:15 PM   #7
LumpyGrits
Use a jumper wire from the POS(+) side of the battery to the POS(+) side of the coil.
See if it starts now----
Don't run it to long-
Pull jumper to 'kill' engine.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 08-18-2014, 08:28 PM   #8
colledrolled
It turns over with the key though.
Unread 08-18-2014, 08:41 PM   #9
LumpyGrits
I know-
Try what I posted.
LG
Unread 08-18-2014, 08:45 PM   #10
colledrolled
Take the plastic ring off of the coil?
Unread 08-18-2014, 08:48 PM   #11
colledrolled
Put the jumper on and then try to start it with the key right? Is that what you are suggesting? Sorry, not allot of experience here.
Unread 08-18-2014, 08:49 PM   #12
LumpyGrits
Yup
LG
Unread 08-18-2014, 09:31 PM   #13
colledrolled
OK I put the jumper on and it turned but it was just the starter. I took the plastic ring off of the coil when I jumped it. What about the green wire? That needs to be on there too no? It sounded closer to starting without the jumper. The engine is cranking. I confirmed with my tester that with the key on, I have nothing at the positive side of the coil.
Unread 08-18-2014, 10:35 PM   #14
LumpyGrits
Yes-That horseshoe connector must be on the coil.
LG
Unread 08-19-2014, 04:17 AM   #15
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Have you checked for a blown fuse? Ign lps fuse.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
