Won't idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Won't idle
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-08-2015, 05:10 AM   #1
mallard3914
1978 CJ7
Won't idle
1978 CJ7 stock 304. Jeep was been running great. Thursday, I left my lights on and drained the battery. I had to jump start it. Since the jump start it will not idle. The choke isn't working either it seems. It will stay running for about 10 sec but rpm is only 500. Prior to Thurs it was 750. Any idea what may be going on?
mallard3914 is online now   Reply With Quote Quick reply to this message
Unread 06-08-2015, 05:28 AM   #2
matt1980
matt1980's Avatar
1980 CJ5
Assume was running great prior to dead battery, I would try to isolate the problem, sounds like you are leaning towards choke, I believe the choke will not work until the engine builds oil pressure, you may try bypassing and run direct power to choke, if it works at least you know that the choke was in fact the problem and the choke works when powered, then turn your attention to wiring that is suppose to power choke or maybe the switch on the block, at least none of this will cost you anything.
matt1980 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 05:53 AM   #3
mallard3914
1978 CJ7
Yes Matt is was running fine till the battery drain. I just wonder if I somehow pulled the power wire off the choke when I was hooking up the jumper cables. Thanks for the insight.
