Won't idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Won't idle
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-09-2013, 07:20 PM   #1
RenoF250
Won't idle
My CJ has gotten worse and worse at idle and now it is to the point that it that if you get below ~1k rpm you have to shut it off, start it, and rev through1k. Otherwise it just sits there and burlbes and backfires. I went to find the problem now that we are home and it was doing it then there was a click like and from a relay and it cleaned right up. I also notice that if I pull the hose of the green sensor on the firewall the engine speeds up and the vac increases. Any ideas of where to look? It is using the stock computer but has an MSD5 (uses the computer controlled coil output not right of the dist pickup like the 6).
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 08:07 PM   #2
melancholy35
What motor?
melancholy35 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 08:45 PM   #3
RenoF250
Originally Posted by melancholy35 View Post
What motor?
4.2L
I just went out to play with it again and it was idling fine, I was checking the timing and then "click" again and it went to hell and the timing was bouncing all over the place.
What has the ability to tell the computer to go to crap mode.
Unread 08-09-2013, 09:31 PM   #4
melancholy35
I would just do the nutter bypass that way you don't have to worry about the computer. Also what coil are you running? I was using the msd blaster and it ran like crap. I went back to the stock coil and no issues. There is also a mod In which you use a distributer cap from a ford which should also help.
Unread 08-09-2013, 09:32 PM   #5
melancholy35
Are you letting it warm up before you check timing? Also are you pluging the dist vacuum line? What condition are your vacuum lines in?
Unread 08-09-2013, 10:25 PM   #6
LumpyGrits
When did you last rebuild the carb?
What mods has there been done to eng/carb/ign?
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 11:18 PM   #7
RenoF250
The coil is a Summit that is supposedly correct for the MSD5. I have an MSD6 that needs to be sent in to get fixed. If that were working I would try it to rule out the computer.
It needs to be smogged in October and I don't think they will let me nutter it. Also, it runs great until the click.
I have the big team rush cap.
Unread 08-09-2013, 11:21 PM   #8
RenoF250
About a year and a half ago. Engine and carb are stock. Ignition is team rushed and MSD5 with Summit coil in place of existing coil. There is also a relay to power the MSD5 that is switched off the red coil wire. It can click but when I shut it off the engine dies as expected so I do not think it is the click I am hearing. That is even louder, sounds like an A/C compressor clutch.
Unread 08-09-2013, 11:24 PM   #9
RenoF250
Yes, it was warmed up when I timed it but this time I was just checking to see what the timing was doing and did not adjust it. I also wanted to make sure it was not bouncing around indicating a bad timing chain. It was unremarkable until the click then it bounced all over.
Take it for a drive a bit ago and it ran perfect at all RPMs and did not exhibit the problem at all.
Unread 08-09-2013, 11:52 PM   #10
86cj74.2L
86cj74.2L's Avatar
Are you able to post a picture of what you disconnect to make it happy?
That click could be a relay for idle control near the battery, or one of the three vacuum solenoids on valve cover.
If its one of the valve cover ones.......they could be open to atmosphere. Creating a vacuum leak which leans out the idle.
When its running ruff spray some brake cleaner around the vacuum lines. You will know when you find it.
86cj74.2L is offline   Reply With Quote Quick reply to this message
Unread 08-10-2013, 10:25 AM   #11
LumpyGrits
I would not use brake cleaner around those PLASTIC vacuum switch fittings etc. that AMC put all over our Jeeps.
I have used very soapy water in a spray bottle for this, with good results.
You will see the bubbles get pulled inside where the leak is.
LG
Unread 08-10-2013, 11:41 AM   #12
RenoF250
I wish I knew what it was that disconnects, I just hear a click. I will try disconnecting the things you mention and see if any of them do it. I generally pinch the lines to see if it makes a difference. I do not think this is a vacuum port opening though because when it is running good I can pull a hose off and it does have nearly the same effect.
Unread 08-10-2013, 01:52 PM   #13
RenoF250
Of course now that I am home it won't do it. I did not see a relay by the battery but there are two light blue ones on the back of the engine. I unplugged each individually with no effect (kept idling well) and the vacuum sensors on the firewall. If I can get it to do it again I will try unplugging them again and see if it starts running well. Nothing quite as fun as troubleshooting an intermittent.
Unread 08-10-2013, 03:01 PM   #14
RenoF250
Not likely related but I was running it trying to get it to do it again and shut it off and it just kept running like nothing happened. Opened the hood and checked the relay to the MSD it was still getting ~4.9V from the coil wire so it was still on.
Unread 08-10-2013, 03:05 PM   #15
86cj74.2L
86cj74.2L's Avatar
When Grammys CJ kept running with the key in her hand it took replacing the starter solenoid
To fix it.
