Won't Crank - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Won't Crank
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 02-04-2008, 09:44 PM   #1
crrushing
Won't Crank
I recently left my jeep on an uphill slope, and then when I went to crank it up it would not crank. The motor turns and tries to crank but wont. When i turn the key to crank it, the motor tries to turn over at the point when i let off of the key. My gas tank is full and when i give it gas, the jets squirt gas into the carberetor so i know it is getting gas. I thought it may be the timing, but i have adjusted the dist several different positions with the same results. Do you guys have any idea as to what may be happening. Any help would be greatly appreciated.
This problem has happened before when it was left on an uphill slope.
crrushing is offline   Reply With Quote Quick reply to this message
Unread 02-16-2008, 12:47 AM   #2
flashawk
flashawk's Avatar
1979 CJ5
If you're alternator is bad and the battery is dead, that would keep it from starting.
flashawk is offline   Reply With Quote Quick reply to this message
Unread 02-16-2008, 01:14 AM   #3
Mr.Crowley
1980 CJ7
its probably floaded..On a hill the float can open and drown the engine..Or just the opposite..Move to levelish ground,hold foot to floor to keep the venturies open in the carb and crank over to see it fires up..On a fully charged battery of course
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote Quick reply to this message
