won't stay put when parked on a hill - JeepForum.com
post #1 of 8 Old 11-14-2009, 12:32 AM Thread Starter
meater
1981 CJ8
so,
when i park on a hill, i put my cj-8 in gear (usually 1st, but sometimes reverse). it will not stay put. rather it lurches and stops until on level ground. whats up here? somebody has suggested bad engine compression, and no real way to fix it. any ideas?
meater is offline
post #2 of 8 Old 11-14-2009, 12:35 AM
Coiz
1979 CJ7
Low compression is the cause of that but you need to remember that it is called a parking brake, not an emergency brake. In gear with the parking brake should be able to hold it and if you think back to your original driving classes, you will remember the reasoning behind turning your wheels towards the curb when parked on a hill.
Mike
Coiz is offline
post #3 of 8 Old 11-14-2009, 12:40 AM Thread Starter
meater
1981 CJ8
is low compression a bad thing?
meater is offline
post #4 of 8 Old 11-14-2009, 12:54 AM
Coiz
1979 CJ7
It means the engine is getting tired. Buy, rent or barrow a compression tester and see what you've got. Be sure to pull all the spark plugs, throttle held wide open, crank the engine and record the 5th reading on the tester. Do this for every cylinder. Then add a tablespoon of oil to the cylinder and do it again. Fairly simple to run. Write everything down and let us know the results.
Mike
Coiz is offline
post #5 of 8 Old 11-14-2009, 01:07 AM Thread Starter
meater
1981 CJ8
meater is offline
post #6 of 8 Old 11-14-2009, 01:22 AM
80cj
80cj's Avatar
1980 CJ5
The problem is compounded if you have high rearend gears and big tires. Put it in low range.
80cj is online now
post #7 of 8 Old 11-14-2009, 05:48 AM
Mike Romain
Yes it is a bad thing.
Mike
Mike Romain is offline
post #8 of 8 Old 11-14-2009, 09:05 AM
IDK
Bad compression means that your motor is nearing the end of it's life and needs to be rebuilt or replaced. You will notice lack of power, and no downhill compression on steep hills. If you have a inline six it probably has close to 300,000 miles on it which is excellent for a motor, those things are hard to kill! It's probably just played out and could use a good rebuild!
IDK is offline
258 won't start when parked on hill JIBTEXHNKA Jeep CJ Forum 21 11-11-2014 08:52 PM
Battery Drains While Vehicle Is Parked macg1777 Jeep CJ Forum 30 04-06-2010 07:40 PM
Spilling Gas on a hill omanalansanjr Jeep CJ Forum 4 01-22-2008 02:05 PM
out of gear going down hill HAWK99 Jeep CJ Forum 4 02-17-2003 08:17 PM
