Won't restart at operating temperature - JeepForum.com
post #1 of 6 Old 09-28-2011, 12:17 PM Thread Starter
dino2000
1976 CJ5
1976 CJ-5, 258, single barrel carb. all smog equipment in tact and passed test with flying colors. Jeep has 101,000 miles on it and I have a fairly complete service history.
I can get in this thing in the morning and it fires right up. The choke functions perfectly. I have replaced ALL of the ignition components. The fuel pump is new. I have flushed the rad, new hoses and new thermostat. It runs down the highway and around town without issue. The problem starts when you shut it off at operating temp. It will not start back up until it has sat or "cooled off" for at least 20 minutes.
I have noticed two things that are odd when this happens. The coil and resistor are so hot that you cant even touch them and the motor won't fire on starting fluid. The coil and resistor are mounted to the side of the motor in the stock location.
I have checked the carb and it DOES flow fuel when this happens. So that leaves me to believe that this must be an ignition problem. Again, all of the ignition components are new.
Magically, after about 20-25 minutes, she starts right up and runs flawlessly. My son and I took the Jeep for it's first real trail ride / overnite camping trip a couple weeks ago and it was a serious PITA to have to wait 20 mins. every time I killed it on the trail. We live so close to so many great trails and I'm less inclined to go because I just can't nail this down.
Any help would be GREATLY appreciated. Thanks in advance, Dino
1976 CJ-5 "Pvt. Pyle"
dino2000 is offline
post #2 of 6 Old 09-28-2011, 12:31 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Have you checked the timing?
Too much initial advance will make them hard to start when hot.
With the coil and resistor mounted next to the engine, I think it's rather normal for them to be hot after running the engine for a while. Or do they get hot immediately upon starting?
Matt
Matt1981CJ7 is online now
post #3 of 6 Old 09-28-2011, 12:34 PM
Jeepican
1976 CJ5
Not sure if this is the "right" answer but if you still have the stock prestolite distributer, this may be your problem. I had that same issue when i first got my 76' but its in the middle of a build so havn't been able to test since.
Best option is to yank that out and put in a HEI / DUI / or teamrush (4wd has a deal on HEI for $99)
Also when is the last time you rebuilt the carb? I ended up swapping that 1bbl carb and intake to a 2bbl intake and mc2100 ... it made a world of difference! (this can be done for under $100 with used parts)
here a couple threads on teamrush options....
http://www.jeepforum.com/forum/f8/ig...-jeeps-990988/
http://www.jeepforum.com/forum/f8/pr...76/index2.html
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #4 of 6 Old 09-28-2011, 12:35 PM Thread Starter
dino2000
1976 CJ5
thanks Matt. Will start it tonite and see how lojg it takes the coil to get boilin'.
I don't have a timing lite, but will get it checked. Wouldn't that show in the way it runs normally? It did diesel a little when i shut it off once, but it only happened that one time. Thanks for thr help. Things' got me BAFFELED!
dino2000 is offline
post #5 of 6 Old 09-28-2011, 12:54 PM
Matt1981CJ7
1981 CJ7
dino,
No worries. I hope it's something simple like timing.
Pinging under load, like marbles in a can, is usually a sign of too much advance. It can be difficult to hear, however, if the detonation isn't too bad.
Does the starter struggle to turn it over when hot? Or does it turn over normally without firing?
Matt
post #6 of 6 Old 09-28-2011, 09:29 PM Thread Starter
dino2000
1976 CJ5
Originally Posted by Matt1881CJ7 View Post
dino,
Matt
turns over normally. will check out the distributor option.
dino2000 is offline
It's hot outside, 258 operating temperature questions! m1a1mastergunner Jeep CJ Forum 17 08-15-2017 08:40 AM
304 Normal operating temperature? Mudviper Jeep CJ Forum 18 05-20-2017 10:49 PM
ideal operating temperature dhardy1357 Jeep CJ Forum 3 05-20-2011 02:25 PM
Does the 258 have an ideal operating temperature? VACJ7 Jeep CJ Forum 15 10-24-2010 04:17 PM
Normal operating Temperature todbld Jeep CJ Forum 5 08-03-2009 08:18 AM
