Won't Crank - JeepForum.com
post #1 of 3 Old 02-04-2008, 09:44 PM Thread Starter
crrushing
Won't Crank
I recently left my jeep on an uphill slope, and then when I went to crank it up it would not crank. The motor turns and tries to crank but wont. When i turn the key to crank it, the motor tries to turn over at the point when i let off of the key. My gas tank is full and when i give it gas, the jets squirt gas into the carberetor so i know it is getting gas. I thought it may be the timing, but i have adjusted the dist several different positions with the same results. Do you guys have any idea as to what may be happening. Any help would be greatly appreciated.
This problem has happened before when it was left on an uphill slope.
crrushing is offline
post #2 of 3 Old 02-16-2008, 12:47 AM
flashawk
flashawk's Avatar
1979 CJ5
If you're alternator is bad and the battery is dead, that would keep it from starting.
flashawk is offline
post #3 of 3 Old 02-16-2008, 01:14 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
its probably floaded..On a hill the float can open and drown the engine..Or just the opposite..Move to levelish ground,hold foot to floor to keep the venturies open in the carb and crank over to see it fires up..On a fully charged battery of course
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
CJ7 will not crank! hummer6504x4 Jeep CJ Forum 2 04-03-2010 08:12 PM
4.0 crank in a 258???? 78treehugger Jeep CJ Forum 20 11-25-2009 02:56 PM
304, hard to crank mccannibal Jeep CJ Forum 16 08-05-2009 05:32 PM
$20 engine needs crank. Bubba Ray Jeep CJ Forum 3 03-26-2009 10:52 PM
Won't Crank?? colby72olds Jeep CJ Forum 21 10-29-2007 12:13 PM
