WJ Disc? on a 86 dana 44 rear - JeepForum.com
post #1 of 14 Old 05-24-2013, 11:09 AM Thread Starter
BlueRubiconrich
Hi I'm looking at putting Disc on my Factory 86 Dana 44 rear axle.
I'm looking to go with junk yark parts.
I know I will have to redrill the rotors unless I get teraflex dual bolt pattern rotors.
What is better a ZJ,WJ or even a JK?
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #2 of 14 Old 05-24-2013, 11:30 AM
82JeepCJ7
1982 CJ7
2dr Suzuki (Geo) tracker rotors are the correct bolt pattern.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 14 Old 05-24-2013, 11:46 AM Thread Starter
BlueRubiconrich
is that front or rear ?and these will fit with the ZJ brakes?
post #4 of 14 Old 05-24-2013, 12:54 PM
waterdowg
Tracker only has Front rotors. You will need to check the with of the rotors. The Tracker 2 dr rotors are about 10mm thick. The tracker 4 dr rotors are 17mm or 22 mm. I can't remember
waterdowg is offline
post #5 of 14 Old 05-24-2013, 01:54 PM
dg6772
I used the same rotors front and rear, from a 1978 cj. I converted mine to GM brakes on all four corners. It took a little work but was not bad.
Dave in Muskegon
dg6772 is offline
post #6 of 14 Old 05-24-2013, 02:03 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
But keeping the e-brake is an issue if using the front rotors. I would love to convert mine to a rear rotor setup but keep the e-brake...
Let me know if you have any luck!
Rick
Cutlass327 is offline
post #7 of 14 Old 05-24-2013, 02:21 PM
dg6772
I plan on using line locks for e-braking. One for front and one for the rear, so I'll have options and it's fairly inexpensive to add to system.
Dave in Muskegon
dg6772 is offline
post #8 of 14 Old 05-24-2013, 04:46 PM Thread Starter
BlueRubiconrich
that's why I'm looking at the ZJ/WJ /JK rear brakes for the E-brake.
post #9 of 14 Old 05-24-2013, 06:48 PM Thread Starter
BlueRubiconrich
86 Dana 44 axle hole spacing
up 2" center of bolt hole to center of bolt hole
across 3 5/16" center of bolt hole to center of bolt hole
Ford 8.8
across 3 9/16" center of bolt hole to center of bolt hole
Looks like better to use ford 8.8 brackets instead of ZJ or WJ.
post #10 of 14 Old 05-26-2013, 09:39 AM Thread Starter
BlueRubiconrich
If I use Ford 8.8 brakes they will fit with a little less work .I will have the E-brake same as a ZJ and Crown Vic. the bottom hole will have to be hogged out and the center hole.
post #11 of 14 Old 05-26-2013, 03:30 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
An alternative would be to get your rotor and caliper, and then make your own caliper brackets. There are a few rotors that might be worth looking into.. Ford F150, CJ D30 (7/8" thick), Sammy/Tracker Rotors, Scout Fronts?.. basically anything with a 5x5.5" bolt pattern that has a "hat" large enough to fit over the axle flange. Then, a Caliper (with parking brake provisions) that will work with the rotor.
On my own CJ, I'm running a Scout D44 rear axle. I was able to take a D30 rotor and fit it over the Scout axle by turning the axle flange down about 1/4" on the lathe. A larger rotor hat wouldn't require that. I then used Caddy El Dorado Calipers (off fleabay). I had to make a 1/8" thick shim to fit under the outside brake pad in order to take up some of space between the rotor and the brake pads. Then, I simply bolted the rotors in place, slide the calipers on them (clocked where I wanted them), and made a simple template from foamboard to make my own caliper brackets.
Not sure if you have CAD capability, but even if you don't, a "foamboard" template of the bracket could be copied in steel pretty easy.
If you can get a good template (or CAD DXF File), hit me up and I can cut it on my CNC Plasma Table from some 3/8" plate. Ship the raw brackets and you could mark/drill bolt holes to make sure they're accurate.
BESRK is offline
post #12 of 14 Old 05-26-2013, 03:45 PM
dg6772
Many racing suppliers sell caliper brackets for little cash. Some even clamp to axle instead of welding.
Dave in Muskegon
dg6772 is offline
post #13 of 14 Old 05-26-2013, 04:05 PM
82JeepCJ7
1982 CJ7
Ford SVT rear calipers work well. And they have a built in parking brake.
post #14 of 14 Old 05-27-2013, 07:39 AM Thread Starter
BlueRubiconrich
thanks guys a lot of good info.
