At Wits end with HEI Distributor - Page 4 - JeepForum.com
post #46 of 50 Old 04-24-2013, 07:36 AM
Caish
1987 XJ Cherokee
Try this,
Run a hot wire straight from the battery to the distributor.
Now there is no question and see if it has fire and cranks.
If so, find a new hot wire that stays hot with the key.
If not your chasing ghosts in the distributor.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #47 of 50 Old 04-24-2013, 07:38 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by VooDoo2 View Post
The block has 2 grounds. One frame to block and one to the battery plus it has the straps on the engine mounts (so really 4 all up). YOu would think a iron block and a new lump of ali would conduct ok but no, it needed sanding and to be shiny to work
Serrated washers are our friends.
Matt
Matt1981CJ7 is online now
post #48 of 50 Old 04-24-2013, 07:41 AM
lucdog
lucdog's Avatar
1980 CJ5
Of the 2 HEI's I have, both of them have a threaded hole on the bottom of the base. I run a #10 or 12 wire from a known good ground to this point.
I think it's a 8/32 machine screw.
Edit, I guess I have 3 of them, this one is a spare. And don't forget the gasket between the dizzy and block.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #49 of 50 Old 04-24-2013, 09:59 AM
86cj74.2L
86cj74.2L's Avatar
Bill
Or you may have oil running down the block.
86cj74.2L is offline
post #50 of 50 Old 04-24-2013, 04:55 PM Thread Starter
VooDoo2
1978 CJ7
Originally Posted by Caish View Post
Try this,
Already tried this a while back and no go. It was the grounding.
VooDoo2 is offline
