At Wits end with HEI Distributor - Page 3 - JeepForum.com
post #31 of 50 Old 01-21-2013, 09:25 AM
CSP
Are you referring to the spark plug wires as "leads"? If so, any '91-95 Wrangler with the 4.0 will have the correct wires to use and will be the right length for the 258.
CSP is offline
post #32 of 50 Old 01-21-2013, 10:48 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by VooDoo2 View Post
This stuff was silver. Ive used enough heat sink grease to know that there was WAY to much on there. It can also act as an insulator (which id say it was as it was in the connectors after squeezing out from under the module)
Got any spec's on the HEI leads and what i should look for? I can order from US but then id be waiting another week for them to get here.
I wonder if it has aluminum or silver flakes in there to help with the heat transfer.
If there was too much and touched the terminals, it could short them out.
John Strenk is offline
post #33 of 50 Old 01-21-2013, 07:35 PM Thread Starter
VooDoo2
1978 CJ7
I bit the bullet and ordered from the USA. Was cheaper than going to a local store who wanted $120+ for them.
John, i found this post from you from 2007. Could this be part of my problems?
The factory tach is wired in series with the coil and control module. If your running a HEI then the power lead supply power to the distributor must come from the tach!! Do not use the tach output on the distributor to run the tach. This is for aftermarket tachs only.
If you ran power from some other source and have the tach in the tach plug then I'm suprised the engine runs at all.
Factory tach hooks up this way with a HEI distributor:
Key----tach----distributor (+)
VooDoo2 is offline
post #34 of 50 Old 01-22-2013, 04:34 AM
John Strenk
1976 CJ5
If you have the two post OEM tach hooked into the "Tach" terminal on the HEI then yes, it could be your problem.
THat is why I was asking about the tach earlier.
post #35 of 50 Old 01-22-2013, 04:46 AM Thread Starter
VooDoo2
1978 CJ7
I was completely ignoring the tach at this point as i wanted to find the problem before adding complexity to the issue. I have the OEM tach but haven't traced the wiring yet. The power wire im using is the large red with a white stripe that fed the ignition module on the fender. I had a green wire going to the old coil feeding back to the fuse-block on the firewall i assume is the tach wire but at this point i havent looked into that further. At this stage im waiting for the new plug leads (or wires as you guys call them). Ive now replaced all the water and oil senders, new fuel pump, new plugs, filters, oil and belts, removed all the excess vac hoses, fixed a vac leak and hooked the charcoal canister back up (it had hoses that fed into the chassis rails and nowhere else lol). The intake heater is also disconnected and wiring removed (the coldest it gets here is 15c in the middle of the night, in winter. i wont need it)
VooDoo2 is offline
post #36 of 50 Old 01-22-2013, 07:23 AM
brownbagg
1930 MK Compass
On lead' the Chevy pickup had a straight six with hei
brownbagg is offline
post #37 of 50 Old 01-22-2013, 12:58 PM
John Strenk
1976 CJ5
Odd about the green wire from the coil feeding back into the firewall plug. The 4 cylinder did this. Not sure about diesels. But maybe export was different
post #38 of 50 Old 01-22-2013, 05:01 PM Thread Starter
VooDoo2
1978 CJ7
My fusebox is in the center of the firewall not in the top corner. Its almost inline with the dizzy. IM going to have to go through the wiring diag and get rid a of lot of spare wires though.
VooDoo2 is offline
post #39 of 50 Old 01-23-2013, 05:26 AM
John Strenk
1976 CJ5
Wow, this is different then. Does it look stock or some PO instalationl?
I assume it's RHD also.
Can you post some pictures?
post #40 of 50 Old 01-23-2013, 05:36 AM
chainz
1976 CJ5
Just a thought but is your engine properly grounded in all of the places that it should be?
chainz is offline
post #41 of 50 Old 01-23-2013, 05:39 AM Thread Starter
VooDoo2
1978 CJ7
Wow, this is different then. Does it look stock or some PO installation?
Yes its stock and RHD. The PO added a much larger power lead to the solenoid and upgraded lead to the starter and other than removing a heap of vac lines the car was 100% stock. ill get a photo in the morning (im at home and its 9:40pm here atm)
VooDoo2 is offline
post #42 of 50 Old 04-24-2013, 07:44 AM Thread Starter
VooDoo2
1978 CJ7
Well after buying
another HEI
New Leads
New Plugs (2 sets)
Net wiring
New Battery
New Solinoid
Rebuild the Starter
re-Setting the timing
Removing and reinstalling at least 30 times
Bench testing (worked there)
The bloody thing still wouldnt work in the car.
I was about to give up but one more try today with a mate who is a mechanic for 50+yrs
He tried everything.. still nothing.
Then we decided to Sand the Dizzy hole, sand the clamp AND add a earth strap to the bolt.
WE HAVE LIFE!!!
Started and idled better than its ever done. The oil impregnated surface wasnt a good enough earth. Also the Starter required more than 12.2v to operate the solinoid on the starter motor. 12.4v and it worked perfect. a slight drop and the engine wouldn turn over.
VooDoo2 is offline
post #43 of 50 Old 04-24-2013, 08:15 AM
magilla
magilla's Avatar
1969 C101
Aha! Glad you found it!
Ensure your engine block is properly grounded to the frame. Same goes for battery, alternator, and starter. Without good grounds, you get gremlins...as you have experienced.
1969 Jeepster Commando w/Buick 231. T14/D20. D30/D44, 4.10 Locked/Spooled. 4x disc brakes, Saginaw PS. 32" x 9.5" Super Swampers.
1970 Jeepster Commando, in pieces. Buick 350 / SM 465 / D20.
magilla is offline
post #44 of 50 Old 04-24-2013, 08:17 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My simple electrical rule is: ITS ALWAYS THE GROUND
Glad you got it running, VooDoo.
Matt
Matt1981CJ7 is online now
post #45 of 50 Old 04-24-2013, 08:23 AM Thread Starter
VooDoo2
1978 CJ7
The block has 2 grounds. One frame to block and one to the battery plus it has the straps on the engine mounts (so really 4 all up). YOu would think a iron block and a new lump of ali would conduct ok but no, it needed sanding and to be shiny to work
VooDoo2 is offline
