wirring manual - JeepForum.com
post #1 of 9 Old 07-22-2007, 12:29 AM Thread Starter
daraduke
wirring manual
Hi Guys...
well my cj8 is driving me nuts... turns out the big ticket items are the eaisest to deal with, its the small things that are causing me stress.
I got a new engine,
removed the old body lift,
solved the old leaky top problem...
BUT every time i turn around i have some wirring problem. I think the PO cut into every wire they could.
I need a good manual with good wirring diagrams and good system overviews.
I have the haynes manuls now its soso, find there is to much covering every other years, gets confusing.
what manuals do you guys suggest?
thanks.
scott in vancouver.
daraduke is offline
post #2 of 9 Old 07-22-2007, 05:24 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
There are some decent digrams floating around the 'net.
However, I was in your shoes not long ago, and realized that the best fix was to start from scratch. I rewired it with a Painless kit, but there are others out there that other people like. While the kit is not cheap, you can do it in a weekend, and eliminate all of of your electrical problems. Everything will be cleaned up and neat, you will know where every wire goes, and you will have the security of knowing everything electrical is going to work.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 9 Old 07-22-2007, 06:34 AM
GPER
1979 CJ7
GPER is offline
post #4 of 9 Old 07-22-2007, 08:46 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Go to your local library. You can find high quality, multi-page fold-out wiring diagrams in the reference section.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #5 of 9 Old 07-23-2007, 10:25 AM
82cjman
1982 CJ7
i used the painless kit as well after my wireing lit on fire. the kit fit great and now everything electrical works great. i would suggest investing the time to save agravation in the future
82cjman is offline
post #6 of 9 Old 07-23-2007, 12:28 PM
jeepskate
Factory Service Manual. You can buy reprints on the web, and I believe the Alldata CD's that you can get from AutoZone contain the same diagrams.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #7 of 9 Old 07-23-2007, 01:29 PM
jfwireless
1976 CJ7
The year specific Jeep Technical Service Manual is your best resourse for the wiring diagram and all other service related issues. If I had only one resourse it would be the year specific technical service manual. I found mine on Ebay a long time ago.
Jim
jfwireless is offline
post #8 of 9 Old 07-23-2007, 04:17 PM
bdmonist
WTF is that?
bdmonist's Avatar
Autozone online also has some wiring diagrams as well. If you have some specific questions, post them up and many will be able to help you out.
I got my FSM on ebay as well for about $60 or so. Keep your eye out, they are on there often.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #9 of 9 Old 07-23-2007, 05:40 PM
fuzz401
1978 CJ7
this is a 78 wiring from the factory manual should be close
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Haynes Manual vs. Chilton Manual??? xbarksdale Jeep CJ Forum 14 02-13-2009 02:22 PM
Messy Dirty Wirring on my CJ7 - Where should I start? GrantPantling Jeep CJ Forum 7 02-13-2009 11:02 AM
Manual to P/S kit asyrus60 Jeep CJ Forum 3 12-15-2007 07:01 PM
79 CJ-7 manual? Ak_guy Jeep CJ Forum 5 06-09-2007 11:01 AM
79 CJ manual? Online manual source?? Ak_guy Jeep CJ Forum 1 05-16-2005 01:26 PM
