wiring in a warn wench - JeepForum.com
post #1 of 3 Old 01-18-2010, 05:14 PM Thread Starter
2nbob
I am ready to do a dedicated ground system for my 83 CJ7 and I want to make sure the warn wench is correctly wired in. The wench positive cable now goes to the solenoid and the ground to the bolt mounting the power steering pump to the manifold. I don't think the wiring to the solenoid is the way to go. Should it go directly to the battery? What size cables should be used for both the -and +? My wench is a an older M8274.
2nbob is offline
post #2 of 3 Old 01-18-2010, 07:41 PM
turnabout
1974 CJ5
I don't think my 'wench' will ever be wired correctly! (sorry, I can never help myself) As for a winch, I would get a close to the main power source (the battery) as possible (even the ground) and use the highest amperage cable possible. Jeephammer has some great posts on how to make cables using welding wire and supplies found locally for much less than auto parts stores -- search brother, search.
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline
post #3 of 3 Old 01-18-2010, 08:01 PM Thread Starter
2nbob
I hope I can wire better than I spell!
2nbob is offline
SBC conversion wiring. What Jeep wiring to keep? DT5150 Jeep CJ Forum 14 01-04-2010 05:11 PM
wiring up a warn 8274 dayriesw Jeep CJ Forum 6 12-15-2009 11:32 AM
Need wiring help on YJ Tach to CJ wiring danheit Jeep CJ Forum 4 12-31-2008 08:24 AM
new warn wilf Jeep CJ Forum 3 02-02-2005 10:11 PM
Brush gaurd and wench Incredable Jeep CJ Forum 6 08-22-2003 07:18 PM
