Wiring questions Help me identify these wires. - JeepForum.com
post #1 of 12 Old 07-17-2010, 11:20 AM Thread Starter
VanFaasenC
I found these wires that the PO have hooked up to a toggle switch.
These came down on the drivers side by the E Brake area. I have search everywhere looking at wiring diagrams and manuals but can't find any info.
They look factory.
Thanks
ths is the connector that was plugged in.
1986 CJ7 -350 Chevy engine, T176 4 Speed, Dana 300 Transfer case, 3.73 gears
Dana 30 front axle w/Detroit Trutrac -Factory Dana 44 rear axle w/Detroit EZ Locker
4in. Skyjacker Softride suspension lift
33in BFG Mud Terrains on 15 x 10 Mickey Thompson Alcoa wheels
VanFaasenC is offline
post #2 of 12 Old 07-17-2010, 11:31 AM
jeepwhore
Looks like the plug for the wipers.....do yours work?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 12 Old 07-17-2010, 11:40 AM Thread Starter
VanFaasenC
Yup Wipers work. I am kinda hoping it is radio? It has no radio now??
post #4 of 12 Old 07-17-2010, 12:32 PM
keith460
Jeep. There's Only One
keith460's Avatar
That is part of the OEM factory fog light switch, less switch. It plugs into another plug hanging off the headlight switch wiring harness that will have a white, black, orange and gray wire going to it. It allowed the fog lights to operate only when the headlights were on low beam only.
1984 CJ-7 Renegade
keith460 is online now
post #5 of 12 Old 07-17-2010, 12:36 PM
mcmud
1983 CJ8
What color is the wire I've painted green?
mcmud is offline
post #6 of 12 Old 07-17-2010, 12:38 PM
keith460
keith460's Avatar
According to the wiring diagram, that wire should be black colored.
1984 CJ-7 Renegade
post #7 of 12 Old 07-17-2010, 12:46 PM
mcmud
1983 CJ8
Thanks, it was that red/tr that had me stumped.
mcmud is offline
post #8 of 12 Old 07-17-2010, 01:04 PM Thread Starter
VanFaasenC
That wire is black.
post #9 of 12 Old 07-17-2010, 01:21 PM
mcmud
1983 CJ8
Thank you. keith460 has you covered.
mcmud is offline
post #10 of 12 Old 07-17-2010, 02:05 PM Thread Starter
VanFaasenC
So nothing really usefull to even use it for?
BTW Thank guys.
post #11 of 12 Old 07-17-2010, 02:59 PM
keith460
keith460's Avatar
If you are looking to power up a radio when the key is either in the "on" or "accessory" position, there is a factory tap connection on the fuse block. It's located on the lower left corner of the fuse block and it will be marked RADIO. A simple male spade connector is all that is needed to tap into the block but you should have an inline fuse running through the same wire that will power up your radio.
1984 CJ-7 Renegade
post #12 of 12 Old 07-17-2010, 05:22 PM Thread Starter
VanFaasenC
I am wired up how. It was a cheap radio with no clock so i did a tempory hack job (sorry to admit) and tapped the cig light until I put something real in. This is a $30 radio just until I feel like putting a real one in.
accessory switch , wire id , wire identification , wiring harness
Need help: please identify TS switch wires (pics) monninen Jeep CJ Forum 10 07-31-2009 10:57 PM
Help identify wires..picture posted mrk3cobra Jeep CJ Forum 19 01-10-2009 02:05 PM
wiring questions LSUtiger Jeep CJ Forum 0 04-15-2007 03:31 PM
Questions On Re-wiring slowcrawl Jeep CJ Forum 3 04-01-2007 06:42 PM
temp senor wires and fuel sender wires adam85cj7 Jeep CJ Forum 31 02-08-2007 02:37 PM
