Wiring problem flush mount LED tail lights - JeepForum.com
post #1 of 17 Old 12-11-2013, 05:34 PM Thread Starter
pyarbrough
New to the forumn and I have a 80 cj7. Bought some LED flush mount tail lights and can't get them wired correctly. The harness has a 3 way plug with a white, green, and white/grey wire. The LED lights has red, black and white wires. I've figured out that green is turn signal, white is brake and white/grey is tail lights. I spliced the red from new LED to green and white wires from harness. Then black to white/grey. Then grounded the white from new LED. Everything seems to work except the tail lights are illuminated bright and won't dim for brake lights to work. Any suggestions would help. Thanks!
pyarbrough is offline
post #2 of 17 Old 12-11-2013, 08:34 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
LEDS:
white = ground
red = turn/brake light
black = tail light
Swap the red and black wire position and see what happens.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 17 Old 12-12-2013, 05:59 AM Thread Starter
pyarbrough
Tried that and everything stays dim with no brake lights at all.
post #4 of 17 Old 12-12-2013, 06:16 AM
AmbuGrl
AmbuGrl's Avatar
you might want to try either of these to get more traffic on your help/ needs:
Electrical - http://www.jeepforum.com/forum/f20/
CJ - http://www.jeepforum.com/forum/f8/
Sometimes people just look past tech requests in GD. Hope this helps
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #5 of 17 Old 12-12-2013, 06:34 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
On the CJ are there two bulbs in the tail light one for the turn signal/brake and another for the tail light? They didn't use a dual filament bulb?
Autozone link to your wiring diagram fig. 15
http://www.autozone.com/autozone/rep...00c1528004b198
post #6 of 17 Old 12-12-2013, 07:51 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by laybackman View Post
On the CJ, are there two bulbs in the tail light one for the turn signal/brake and another for the tail light?
No and yes (or is it no ((Not sure on the grammer in your second question)),
there are two bulbs in the tail light but one is the backup light and the other DUAL filament Brake/turnsignal and Running light.
John Strenk is offline
post #7 of 17 Old 12-12-2013, 08:09 AM Thread Starter
pyarbrough
Yes the old tail lights have 2 bulbs. One for brake and turn signal the other for tail light. The new LED is a double fillament. Do I have to add a relay in one of the circuits? Sorry I'm not much of an electrician.
post #8 of 17 Old 12-12-2013, 08:10 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
On the dual filament bulb remove one of the wires. using a multi meter test it for voltage when you turn on the lights.
If you see voltage that is your tail light filament.
No voltage?
Shut the lights off and hit the brakes. That wire should now show voltage and is your brake/turn signal wire.
The other one going to that bulb is your tail light filament. The third wire is ground
post #9 of 17 Old 12-12-2013, 08:14 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
OK, if it has two bulb that are single filament and each have the following purpose
1 bulb for tail lights and the second bulb for turn signal/brake function that makes it even easier. Since you know which bulb does what then wire up the LED using the proper wire from each bulb to make the LED work
post #10 of 17 Old 12-12-2013, 09:17 AM
EgulAye
1980 CJ5
The old lighting circuit combines Brake and Turn into a single wiring connection. When you use the turn signal that light has the brake circuit overridden. If your new lights have separate bulbs for each function then you'll have an issue regardless of what you try. It's like setting up trailer wiring on a vehicle that has the turn signals separate from the brakes, only opposite. The CJ has turn and brake combined into a single filament. Parking lights are on the second filament (dim). The second bulb on a CJ is for reverse lights (backup lights). What did you buy exactly? Do you have a link to the product page? Photos you can post, 1 of the wires and 1 of the light as mounted? Does the new light fixture include a reverse lamp?
It sounds like you have an extra LED "bulb" that you don't need in there...
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #11 of 17 Old 12-12-2013, 10:20 AM
John Strenk
1976 CJ5
Well it should not be that way. Maybe the PO did something to screw it up.
Can you email me a picture of your tail light?
There are lots of problems here otherwise.
If the PO had wired the brake lights and turn signal to work on two different bulbs then you will need an adapter like you would use in trailers. This might of been caused by a faulty turn signal switch. He would of needed to run some new wires in the harness to make this work.
But you say it still has the original 3 way plug for the lights so that can't be unless the PO did some creative wiring and spliced in the brake line to the backup lights circuit and and and... well you see that this can get into a big mess...
And if you have a bad ground to the original tail light, then it can 'appear' to be working the way you describe but that's just magic...
So contact me via PM and I'll send my email address. or post the pictures to an online site and post the link.
post #12 of 17 Old 12-12-2013, 12:54 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Here is diagram #15
post #13 of 17 Old 12-12-2013, 01:19 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The left hand turn lamp gets a signal from the turn signal switch along a LT GRN/TR wire.
The right hand turn lamp get a signal from the turn signal switch along a LT GRN wire.
So, each of the tail light bulbs gets one wire from the turn signal switch depending on the side they are on.
Note the stop lamp switch ALSO goes through the turn signal switch through a pink wire, so does the hazard flasher switch.
Which means that the tail lamps become brake lights when you activate the brake lamp switch. The tail lamp bulbs are double filament if I read that diagram right.
Their wiring becomes common in the turn signal switch so it seems.
So when you hit the brakes the stop lamp switch activates BOTH tail light bulbs....I think
post #14 of 17 Old 12-12-2013, 04:23 PM
John Strenk
1976 CJ5
No you are getting it. the turn signal switch is even more complicated in that it also isolates the front turn signals from turning on when the brake is activated. and joins them all back together , front, rear, left and right when the hazard flashers are activated
https://www.youtube.com/watch?v=WNei6auqXys
post #15 of 17 Old 12-12-2013, 04:52 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
That turn signal switch is like Grand Central Station!
