Wiring the igntion with a relay - JeepForum.com
post #1 of 5 Old 09-02-2012, 12:44 PM Thread Starter
jordanhc
I recently aquired an 85 CJ-7. The PO left me with the standard hacked up wiring harness with lots of very poorly connected splices in it so I've been going through and replacing much of the wiring. Found the power wire from the ignition switch going to ignition control module and the ignition coil and noticed its an 8 gauge. I don't really know much about ignition systems but I assume if it needs an 8 gauge wire it must pull a lot of amps. Seems to me that running all that power through the ignition switch is a bad design and I should rewire it through a relay. So the question is, is this a good idea? Also, how many amps would the relay need to be rated for?
jordanhc is offline
post #2 of 5 Old 09-02-2012, 02:38 PM
86cj74.2L
86cj74.2L's Avatar
The factory wire size I thought was a #10.
But yes I thought about clipping the red with white stripe as it came through the firewall and having that wire energize a relay and then using that relay output to re-feed the red with white stripe wire to remove most of the load from the ignition switch.
A 30a relay should do it.
86cj74.2L is offline
post #3 of 5 Old 09-02-2012, 09:03 PM Thread Starter
jordanhc
Thanks for the info. I think I will go to the junkyard tomorrow and see if I can find a relay box to put all the loose relays in and add in relays for the ignition and headlights as well.
jordanhc is offline
post #4 of 5 Old 09-02-2012, 11:58 PM
86cj74.2L
86cj74.2L's Avatar
Try a s series Saturn. Take the hole under hood junction box. Rewire it as needed.
post #5 of 5 Old 09-03-2012, 02:48 AM
BagusJeep
1981 CJ7
It is rare to get the switch to fail just because of the ignition current. The ignition circuit is not even fused as it is a reliability issue, dead fuse / relay = stranded CJ.
It is also means any future owner will curse the PO (you) for putting in a relay.
However there are plenty of circuits which would benefit from relays and heavier power and return cables, lights being a major one. The voltage drop along those undersize wires kills the lights.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
Start Solenoid and a Relay Wiring I.D. Help frank c Jeep CJ Forum 15 01-28-2012 05:08 PM
headlight relay wiring Bakunin Jeep CJ Forum 6 01-31-2011 01:50 AM
Driving Light wiring/relay starfire340 Jeep CJ Forum 2 05-15-2008 10:15 PM
Relay wiring diagram? armyhooker Jeep CJ Forum 4 05-15-2008 08:59 AM
Relay Wiring Document, JeepHammer Jeep CJ Forum 19 01-19-2008 12:13 AM
