Quantcast Wiring an ignition kill switch... Which wire do I tap/cut in to? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wiring an ignition kill switch... Which wire do I tap/cut in to?
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 11-09-2008, 02:49 PM   #1
jatepper
jatepper's Avatar
OK. Wiring an ignition kill switch in to my tuffy center console. Can't find my Chilton. Which wire coming from the steering column do I cut in to and wire to the switch?
Thanks.
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Torchmate CNC Plasma Table Build / Projects
Handen Fabrication
jatepper is online now   Reply With Quote
Old 11-09-2008, 03:02 PM   #2
John Strenk
What was I thinking
1976 CJ5
Do you have the factory tach?
If not there is a very convient plug just off the ignition swich you can use for this 'Kill" switch. Of course it would be easy for someone to defete if they know CJ's
John Strenk is online now   Reply With Quote
Old 11-09-2008, 04:18 PM   #3
jatepper
jatepper's Avatar
Thanks John. Is this inside the engine compartment of under the dash? I looked and could not find this.
Yes, I have a factory tach.
1985 Jeep CJ-7
Handen Fabrication
Old 11-09-2008, 05:09 PM   #4
jeepsta
1983 CJ5
Sorry to hijack, but along the same lines, Could you use this set of wires to put in a push button starter?
83 CJ, yeah its a 5
1. Christopher Columbus did not need directions and neither do we.
jeepsta is offline   Reply With Quote
Old 11-10-2008, 07:40 PM   #5
my-jeep-earl
1971 CJ5
It is under the dash, that part next to the awl/pick is the ignition switch which is mounted on the lower steering column, start from there. Good luck.
my-jeep-earl is offline   Reply With Quote
Old 11-10-2008, 09:06 PM   #6
jatepper
jatepper's Avatar
So, with the help of the picture, I can run the each open line from the tach to their own respective side of the switch and this will keep the ignition/coil from getting power?
1985 Jeep CJ-7
Handen Fabrication
Old 11-11-2008, 12:04 AM   #7
my-jeep-earl
1971 CJ5
Mount the switch where you want it, run two wires the same guage from the switch and hook up to each side of that plug. Your good to go!
Old 11-11-2008, 08:02 PM   #8
jatepper
jatepper's Avatar
OK...still do not see this thing under my dash. What is the awl/pick?
I see nothing like this mounted to the lower steering column
1985 Jeep CJ-7
Handen Fabrication
Old 11-11-2008, 09:52 PM   #9
rrisher
1987 YJ Wrangler
The coil wires aren't mounted to the column they go to the gauge in the dash and then to the wire harness as shown in the picture in post #2.
I don't think so... These wires just go to the coil! To start the vehicle you'd have to power the starter solenoid to get the engine turning....
rrisher is offline   Reply With Quote
Old 11-11-2008, 10:15 PM   #10
my-jeep-earl
1971 CJ5
The awl/pick is that sharp thing with the bent tip and the screw driver handle on it.
Do you have a steering column with the ignition key in the column or is the key mounted on the dash?
Old 11-12-2008, 06:57 AM   #11
John Strenk
What was I thinking
1976 CJ5
on top of the column between the dash and the firewall:
unless someone moved it already.
Old 11-12-2008, 10:01 AM   #12
jatepper
jatepper's Avatar
Thanks John and Earl!
Mucho appreciatato
1985 Jeep CJ-7
Handen Fabrication
Old 11-12-2008, 10:50 AM   #13
jfwireless
1976 CJ7
I need to think of the best place on my junkyard TBI set up for a kill switch most would never find as it is not stock Jeep and hopefully not just ignition dependant.
Thinking of things like:
Power to fuel injectors
Fuel pump relay
power to ECM
Ignition is always a possibility, but with a simple jumper under the dash most auto thieves can figure that out very quickly.
I have four relays not one feeding Fuel Pump, Ignition, Fuel Injectors, and ECM. I did this for easy fault detection and to be able to monitor these functions independently with simple led's mounted on the four relays, all four have their own fuses, so any short/fault can be found much quicker on the trail.
I wonder if my ECM has any provisions for lock out or security, I have the EBL Lockers board so maybe there are some more ways to disable the CJ.
Jim
jfwireless is offline   Reply With Quote
Glock Forum
