Wiring Harness - Page 2 - JeepForum.com
post #16 of 24 Old 09-13-2009, 03:30 PM
mwhanson
1967 CJ5
Go with EZ wiring...I put one in my 67 CJ5, no problems, and it show's you every 6inches or so what the wire is for (printed on the wiring), comes with a instruction manual that covers about everything. Very easy, and very affordable!!
mwhanson is offline
post #17 of 24 Old 09-13-2009, 05:42 PM
Mike Romain
I recently put a Centech harness in my 86 CJ7 and it went in really well. Their wires are also marked all along and I got it on a web sale.
Mike
Mike Romain is offline
post #18 of 24 Old 09-13-2009, 05:59 PM
adamsclarke
I know this is an old thread, but does the EZ harness replace all under hood wiring, or just dash stuff? Other than the coil, dist, alt, temp there isn;t much more under the hood, but it'd be good to know before I order one.
adamsclarke is offline
post #19 of 24 Old 09-13-2009, 06:40 PM
26679cj5
im pretty sure it does all the under hood wiring.
i would like to know if the new fuze box fits directly where the old one was and attaches easily without having to drill new holes (i have a 76 cj5).
26679cj5 is offline
post #20 of 24 Old 09-13-2009, 08:11 PM
mwhanson
1967 CJ5
It's seperated in to 4 sections...under hood/grill (headlights), dash, steering column, and rear. Also for under the hood you have brake light switch, and all lights on the grill. It's a great system, cheap (than most), and very easy. I have some electrical exp, and I did all mine myself and so far no problems or fires.
mwhanson is offline
post #21 of 24 Old 09-14-2009, 03:08 PM
47redwillys
1967 CJ5
I'm putting an EZ 12 circuit in a CJ5, 1967 and I would recommend it. It is flexible enough to add things like back-up lights and relays for the ignition and headlights. At $115, it is a good deal. It gets my vote.
47redwillys is offline
post #22 of 24 Old 09-14-2009, 04:13 PM
skidplate77
1977 CJ7
I am trying to finish up wiring my CJ7 with Painless Wiring Harness. I am not able to get power to the loom / fuse box. I am figuring that I might have a bad solonoid. Do I get power to the fuse box off the "I" side of the solonoid?? I like the Painess Wiring, pretty easy to install...
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock..
A new work in progress, and a new lease on life...
skidplate77 is offline
post #23 of 24 Old 09-15-2009, 05:54 AM
Mike Romain
Well on my Centech harness, the fuse panel power came from the 'battery cable' post on the solenoid so the fuse panel has power all the time for things like accessories and radio.
Mike
post #24 of 24 Old 09-15-2009, 06:02 AM
alex211
1995 XJ Cherokee
The fuse box power has to come from the postive on the battery. The I terminal on the solenoid is for the ignition when you crank the engine, retards the timing for easier starts.
95 xj bone stock for now
alex211 is offline
Wiring harness on a CJ-7 with an AMC 304? jfrdog Jeep CJ Forum 13 01-10-2011 05:51 PM
75 wiring harness on a 73 quader400 Jeep CJ Forum 1 03-12-2007 02:31 PM
Wiring harness EDs Jeep Jeep CJ Forum 3 02-18-2007 07:47 PM
ez wiring harness nichols077 Jeep CJ Forum 3 01-07-2007 11:24 AM
New wiring harness Theodore Jeep CJ Forum 0 02-05-2005 11:09 PM
