Wiring on gauges - JeepForum.com
post #1 of 6 Old 07-27-2013, 09:38 AM Thread Starter
CaddyRedCJ7
Wiring on gauges
I have a 1977 CJ7 and my fuel and temp gauge didnt work. I found new gauges for 40 bucks shipped and replaced them. I put all the wires and the jumper bar back where it was when I took them off only to figure out that the jumper bar and the purple wire were both on the wrong post on the temp gauge and the jumper bar was on the same post as the red wire on the gas gauge. Today I put the wires and the jumper bar in the right locations but still no gauges, so could the gauges be fried due to the wires being switched around or should the new gauges be ok and I have a different issue with them not working?
-77 CJ7 304 3 speed cadillac red paint sony cd player alpine 6x9 JL audio 10" sub 33" AT tires
CaddyRedCJ7 is offline
post #2 of 6 Old 07-27-2013, 12:33 PM
John Strenk
John Strenk's Avatar
1976 CJ5
i would check the resistances and see if anything burnt up.
See below...
John Strenk is offline
post #3 of 6 Old 02-05-2014, 04:53 AM Thread Starter
CaddyRedCJ7
Ok so yesterday I tested the resistance on the gauges and everything seemed to be within range. I checked all fuses again (my fuse panel labels are hard to read so I don't really know which fuse is for what) so what is the next thing I should check?
post #4 of 6 Old 02-05-2014, 09:07 AM
texasdave
texasdave's Avatar
1980 CJ7
Are you testing them out of the dash panel to see if they work? The cluster has to be grounded by the mounting screws to the dash panel to complete the circuit.
texasdave is offline
post #5 of 6 Old 02-05-2014, 09:47 AM
John Strenk
1976 CJ5
As TexasDave ask, Are you checking this in the jeep or on a work bench?
If it's in the jeep Disconnect your ignition coil before you burn up the coil or the ICM.
Connect a good ground to the cluster housing.
Makes sure the cluster housing is grounded
Turn the ignition key to ON.
With the gauge properly grounded and power lead attached make sure you have power at the terminal:
Then Check that the "A" terminal, the one the strip is connected to, is flashing
Temporarily short the "S" terminals on each gauge to ground and see if the gas gauge moves to full or the temp gauge moves to Hot.
If this is good then you can move onto checking the ends of the sensor leads to see if current is reaching the sensors.
The Temp sensor is easiest.
The fuel tank is harder:
post #6 of 6 Old 02-06-2014, 12:03 PM Thread Starter
CaddyRedCJ7
I had them out of the dash but had the housing grounded to the bolt that grounds my fog lights.
