!#%$&*&^%%$$% Wiring!!!! - JeepForum.com
post #1 of 8 Old 03-22-2007, 02:09 PM Thread Starter
brc75654
Went to get an inspection & my passenger blinker don't work when my head lights are on.....Thanks P.O. you hack! Any ideas...
Thanks JF
Brandon
1979 CJ7 with a 304 V8
brc75654 is offline
post #2 of 8 Old 03-22-2007, 02:35 PM
4XGore
2 chicks at the same time
4XGore's Avatar
1980 CJ7
Check your light sockets for corrosion. I had all kinds of light issues and had to buy new turn signals for the front and now everything works.
4XGore is offline
post #3 of 8 Old 03-22-2007, 03:12 PM
Fuzz21
Fuzz21's Avatar
check your grounds thats the most likely source, remove the light and check all the connections and make sure the screwa are tight and aren't rusted and don't wobble in the hole.
1985 CJ-7, 258 w/a weber carb and HEI, 2.5"lift w/32" tires, 1/2"shackle lift, Dana 300, T-5, AMC 20 w/one piece axels, and Dana 30, YJ tub swap w/CJ tailgate, chevy blower motor upgrade, homeade body sliders, flush mount LED taillights......much more to come!!
"And on the eigth day, Man created BEER!"
Fuzz21 is offline
post #4 of 8 Old 10-14-2013, 11:43 PM
airjeep
1975 CJ5
I agree. your turn signal is a complete seperate signal ( positive voltage)... It HAS to be a ground issue.. With the taillights on, there just isn't enough neg voltage to power both.
airjeep is offline
post #5 of 8 Old 10-14-2013, 11:46 PM
airjeep
1975 CJ5
Hmmm. quick question, do both brake lights work with the h-lights on?
airjeep is offline
post #6 of 8 Old 10-15-2013, 02:22 AM
LumpyGrits
Work the turn sig lever up and down(ign OFF)a couple of dozen times.
The contacts get dirty and you loose your turn sigs.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #7 of 8 Old 10-15-2013, 05:19 AM
keith460
Jeep. There's Only One
keith460's Avatar
Brakes lights should illuminate anytime you depress the brake pedal, regardless if you have your headlights on or not.
What are you asking? Are you having problems with brake lights not coming on when the headlight switch is pulled or are you questioning the OP, who posted the question back in the beginning of 2007?
1984 CJ-7 Renegade
keith460 is offline
post #8 of 8 Old 10-15-2013, 11:30 AM
John Strenk
John Strenk's Avatar
1976 CJ5
2007,
Wonder if he ever got them working or not.....
John Strenk is offline
SBC conversion wiring. What Jeep wiring to keep? DT5150 Jeep CJ Forum 14 01-04-2010 05:11 PM
DIY wiring TACAMO Jeep CJ Forum 8 10-22-2009 05:48 PM
Need wiring help on YJ Tach to CJ wiring danheit Jeep CJ Forum 4 12-31-2008 08:24 AM
Wiring Help!?! collinpyle Jeep CJ Forum 5 03-16-2006 02:32 PM
Wiring Fropleyqk Jeep CJ Forum 17 05-19-2005 05:10 AM
