Wires... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wires...
JK Front Lower Adjustable Control Arms!QTP Low Profile Cutouts Now @ MarylandSpeed- Free ShippingOPTIC ARMOR WINDOWS all sale now !!!!!!!!
Unread 04-16-2014, 05:07 AM   #1
pdivico
Wires...
Hi to everybody,
Itís a long time that I follow this forum without writing, I see a lot of good ideas here, thank you very much.
Now I would like to change my wiring harness with a new kit, What you recommend me? My Jeep now is without computer, and I have a Weber 38 and a DUI distributor. I want to clean a little bit all the wires that goes to anywhere.. and change de fuse block.
Sorry for my writing, Iím American but I live at Rome from 40 years..
CIAO
pdivico is offline   Reply With Quote
Unread 04-16-2014, 05:11 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I put a Centech harness in mine. It went in really easily. All the wires are marked and have the plugs and sockets already in place. It also had a dedicated ground system in it so you don't have to rely on fixture bolts or the tub for ground.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 04-16-2014, 06:24 AM   #3
82JeepCJ7
1982 CJ7
Build your own so you don't add circuits and wires you don't need. All the kits have all the extra wires in them.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 04-16-2014, 06:28 AM   #4
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I agree.
Also, you should consider hooking your PCV system up properly.
Matt
Matt1981CJ7 is online now   Reply With Quote
Unread 04-16-2014, 06:31 AM   #5
kirbot
1981 CJ7
I rewired my engine bay a little bit at a time. If you take it slow it isn't so overwhelming, and you can save a lot of money.
If you're doing it all at once though, I'd start with something like an EZ wiring kit. It's a generic kit meant to fit a lot of vehicles.
It'll cost about 1/3 of a Painless or a Centech, but still be easier than starting from scratch.
Let your caffeine levels drop back down to normal and breath a little.. -MoC
kirbot is offline   Reply With Quote
Unread 04-16-2014, 10:35 AM   #6
Tigerjeep79
Tigerjeep79's Avatar
1979 CJ7
A couple of years ago my wife gave me a Painless kit for Christmas. Coupled with the DUI distributor, it really cleaned up the engine compartment.
Tigerjeep79 is offline   Reply With Quote
Unread 04-17-2014, 01:53 AM   #7
pdivico
Thanks to everybody,
Probably I try to change the wire once at time, can I use the wire a little bit bigger or I have problems with the resistance? Also for Matt, what happen on my PCV system is something wrong?
CIAO
Unread 04-17-2014, 02:34 AM   #8
grnd93
It would appear your PCV valve has been removed and replaced with regular crankcase breathers. I wouldn't worry about it
grnd93 is offline   Reply With Quote
Unread 04-17-2014, 05:04 AM   #9
John Strenk
John Strenk's Avatar
1976 CJ5
even the early '60s vehicles had road draft tubes to suck the fumes out. Not just vents. He really needs something to draw the fumes out.
John Strenk is offline   Reply With Quote
Unread 04-17-2014, 06:17 AM   #10
Matt1981CJ7
1981 CJ7
Probably I try to change the wire once at time, can I use the wire a little bit bigger or I have problems with the resistance? Also for Matt, what happen on my PCV system is something wrong? CIAO
As John said, the system is designed to circulated fresh air in and dirty air out.
The rear hole in the valve cover is the fresh air intake. The front hole contains a PCV that is connected to manifold vacuum.
Go here for a more detailed explanation.
Matt
Unread 04-17-2014, 06:23 AM   #11
82JeepCJ7
1982 CJ7
PCV systems suck.....
Unread 04-17-2014, 08:34 AM   #12
pdivico
So Matt if I want to do the correct thing I need to put the PCV from the carburetor and the other I leave go to the canister like the pic under, it’s right?
Unread 04-17-2014, 08:50 AM   #13
Matt1981CJ7
1981 CJ7
Not exactly.
The little filter on the rear of the valve cover can remain, since you no longer have the factory air cleaner setup. You need to replace the little filter on the front of the valve cover with the correct PCV valve, then connect it to a manifold vacuum source at the carb.
Matt
Unread 04-17-2014, 08:53 AM   #14
Mike Romain
The front hole in the cover goes to the base of the carb area, it is suction out and needs a manifold port. The small air filter in the back hole is OK, that is the air into the crankcase.
This flow is needed to keep condensation out of your engine.
Mike
Unread 04-17-2014, 10:41 AM   #15
grnd93
Plenty of vehicles (mostly in performance applications) do just fine with 2 breathers. One of the purposes is to relieve crankcase pressure caused by combustion gas blow-by past the piston rings.
