Wire wheel and flap disc help - Page 2 - JeepForum.com
post #16 of 22 Old 05-22-2010, 08:20 AM Thread Starter
Skerr
Originally Posted by CJATE View Post
Looking at them in the store, I thought flapper discs were a joke. Buddy convinced me to try them.
All I use now. I tossed all my other clean up and grinding disks. Only cut off wheels and flapper discs. HF will run specials and sell the 60G in packs of 3 for 5 bucks or so. The name brand ones are better and last longer, but they are not 450% better.
I use to remove paint
Grind welds flush
Take down mettle
Ectů
Originally Posted by blackhawk51 View Post
my family and i used the flap discs on some angle grinders to do the entire body on my 5, worked like a charm and only took about 2 days working on and off. I can't give my results for the frame, we sandblasted that. The braided wheel worked extremely well on the underside of the tub to get excess dirt and stuff off.
I bought only one flapdisc, just to try. It for sure was fast, but loaded up as 243 mentioned. I'll pick up some coarse grit today. This frame is in good shape as I have already cleaned it up once. I am redoing it now because of incorrect prep work previously. I wear a dust mask, especially with the flapdisc. Thanks everybody for your input. This has been a big help.
Scott
Kerrdog
Go Fish! <*////><
Skerr is offline
post #17 of 22 Old 05-22-2010, 09:00 AM
243
1978 FSJ Cherokee
Scott,
I would not use flap discs for the initial material removal on the frame, it will take forever!
Use the wire wheels and go back over it with a course flap disc.
Dave's 78 Build
243 is offline
post #18 of 22 Old 05-22-2010, 02:02 PM Thread Starter
Skerr
Originally Posted by 243 View Post
Scott,
243- Thanks. I agree with you. I figured it out with OJT!! I'll stop posting in this thread and continue in my Bedliner for Frame Paint thread, so as not to duplicate. Your advice on the 36 grit was spot-on! Got three of them!!
Scott
Kerrdog
Go Fish! <*////><
Skerr is offline
post #19 of 22 Old 05-22-2010, 07:04 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might also consider shooting the old finish with "Aircraft Stripper".. paint stripper. It comes in both brush on and aerosol cans. Shoot it on, let it sit a few minutes (don't let it dry) and then scrape it off with a putty knife. It will blister most finishes almost immedieately (including powder coating) and slough off really easy. Scrape large areas, then come back over with that knotted wire cup.
Should be able to easily strip an entire frame to bare metal in about 1 day.
Keep in mind that paint stripper is harsh. Eye protection, chemical gloves, respirator and a tarp (to collect the junk that falls off) are the order of the day.
BESRK is offline
post #20 of 22 Old 05-22-2010, 07:29 PM Thread Starter
Skerr
Thanks, BESRK. Even with the new abrasives this is still a tough job. I have some on the shelf in the garage. We'll try that tomorrow evening.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #21 of 22 Old 05-22-2010, 07:32 PM
SeaWulf
1983 CJ7
Which is best to use on surface rust on sheet metal? the flap disc?
SeaWulf is offline
post #22 of 22 Old 05-22-2010, 08:00 PM Thread Starter
Skerr
The flapdisc flat doesn't play! Pick up the grit that you want and you can rock-n-roll. Another option that would work very well is a sanding disc on a grinder. Check out the thread Bedliner for Frame Paint... I have a picture of the sanding disc I used. Someone mentioned earlier about using a mask... either of these methods will create copious amounts of dust, so be sure to have something handy.
Kerrdog
Go Fish! <*////><
Skerr is offline
wire wheel and flap disk education please twoleos617 Jeep CJ Forum 8 12-14-2009 08:17 AM
Wheel disc splash guard shok47 Jeep CJ Forum 4 09-29-2009 05:24 PM
4 wheel disc brake conversion kit for my 81 cj7 JSCHAFER2233 Jeep CJ Forum 1 07-26-2009 11:05 AM
What has been the general consensus regarding prop valves and 4 wheel disc brakes NWA_CJ7 Jeep CJ Forum 6 03-31-2009 08:39 AM
steering wheel dissambely harness wire problem akashooter Jeep CJ Forum 2 06-28-2007 09:05 AM
