wire question - JeepForum.com
post #1 of 14 Old 04-25-2013, 08:53 PM Thread Starter
neal90
1982 CJ7
wire question
ware does this wire go??? And whats it fore??
neal90 is offline
post #2 of 14 Old 04-25-2013, 09:14 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
It connects to the side of the transmission and powers the backup lights, I think.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #3 of 14 Old 04-25-2013, 09:28 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Judging by your profile info, I'd say it's for the "4wd engaged" light on the dash.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #4 of 14 Old 04-25-2013, 09:39 PM Thread Starter
neal90
1982 CJ7
but ware on the trans does it connect
neal90 is offline
post #5 of 14 Old 04-25-2013, 09:43 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
I believe that goes on the drivers side. Should see the 2 pronged connector sticking out from case.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #6 of 14 Old 04-25-2013, 09:57 PM
zeronight
1982 CJ7
that is the 4wheel drive dash light wire. it does not connect to the transmission it connects to the transfer case on the passenger side (assuming you have a dana 300 transfer case). the back up light connector is a 2 wire connector that is on the tranny on the driver side (assuming you have a t4/t5 tranny)
zeronight is offline
post #7 of 14 Old 04-25-2013, 10:00 PM
zeronight
1982 CJ7
after looking again closer at the picture i see i was mistaken. that IS the 2wire back up light connector. sorry. it is possible that the connections on the switch have broken off but it is on the driver side.
post #8 of 14 Old 04-25-2013, 10:10 PM Thread Starter
neal90
1982 CJ7
i do have a t-5 and plugged it in. I read that the quadra trac was the only jc7 that had a 4x4 light. Does that mean i dont have the original speedo cluster and if so why is the 4x4 light on
neal90 is offline
post #9 of 14 Old 04-26-2013, 12:19 AM
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
4x4 light will stay on if the sender is bad, it's in 4WD, or in my case the PO pinched the wire between the block and bell housing and grounded it out.
HALOjmpr is offline
post #10 of 14 Old 04-26-2013, 03:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Jeeps with the dana 300 had a "4-Wheel Drive" light I think the Quadratec had "Emergency Drive."
Never had one that said "4X4"
Those whith a Dana 20 didn't have either. although the light was always there, just not connected.
John Strenk is offline
post #11 of 14 Old 04-27-2013, 11:00 AM Thread Starter
neal90
1982 CJ7
I looked under the dash. The wire going to the 4x4 light that is staying on is orange. The one going to the emergency break light has 2 wiser one black one read. Question are they in the correct location.
neal90 is offline
post #12 of 14 Old 11-14-2013, 06:02 PM
glasybarel
1982 CJ7
The "pigtail" connecting the backup lights to my T-150 transmission broke off. Any reason I shouldn't be able to strip the wires back half an inch or so, slip a heat-shrink female adapter on each, and then use brush on electrical tape to seal things up nice?
Thanks!
glasybarel is offline
post #13 of 14 Old 11-14-2013, 09:36 PM
BagusJeep
1981 CJ7
Red and black on the brake warning lamp is correct.
The 4WD indicator lamp should be orange and red. The red is a power feed and the orange goes down to the transfer box through the bulkhead connector to ground.
If you ONLY have an orange wire and it is live you probbaly have it wired to the dash panel lamps which confusingly also have an orange wire.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #14 of 14 Old 11-15-2013, 06:56 AM
John Strenk
1976 CJ5
Thanks!
I've never tried brush-on-tape but that's the general idea to make it work.
