Wiper switch w/pictures- what should I do? - JeepForum.com
post #1 of 16 Old 04-01-2011, 01:39 PM Thread Starter
abbjax
1979 CJ7
Hi- I have a 79 CJ7 that I am redoing. A friend is helping me rewire the dash and suggested I replace the wiper switch The existing wiper switch is "square" and one of the terminals is loose. Local auto parts stores dont carry a new switch so I orderd one off Quadratec -says fits 68-82. There is a clip that fits on 3 terminals on the old switch but will not attach on the new switch. Has anyone run into this/ is there an alternate part that may work? In the picture the new one is on the left and the old is on the right. Thanks
abbjax is offline
post #2 of 16 Old 04-01-2011, 04:17 PM
Alby63
1982 CJ5
To me, it looks like the two upper tangs in pic just need to be adjusted.
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #3 of 16 Old 04-01-2011, 04:51 PM
Matt_G
1979 CJ5
id call them up and let them know, they described it wrong and there is no way that will fit without modification. call them and tell them their description is wrong and dont pay for return shipping either, since it is not your fault, its all on them. I think 4wd has the right style switch, not sure
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline
post #4 of 16 Old 04-01-2011, 05:13 PM Thread Starter
abbjax
1979 CJ7
Thanks for the responses- Looks like the customer service dept is closed until Monday. Maybe I received a dud and will ask them to send another/ ask if anyone else has had an issue.
abbjax is offline
post #5 of 16 Old 04-01-2011, 05:32 PM Thread Starter
abbjax
1979 CJ7
I called 4wd.com and there is a specific switch that works with the 3 prong plug. They are shipping it to me and when I mentioned Jeep Forum the guy shipped it for free! I'll send the other one back for a refund/credit. Thanks everyone for helping me out
abbjax is offline
post #6 of 16 Old 04-01-2011, 11:16 PM
248107
1983 CJ7
see if this helps
248107 is offline
post #7 of 16 Old 04-02-2011, 06:44 AM
only in a jeep cj
Your old one is for the harness used in pre 1983 where there was no intermittent wiper option. There is a center 3 prong plug that comes from your wiper motor and a the other two prongs are the red and yellow wires coming from your dash harness. The later style harness has the same two wires, but they come down to a circular plug that fits either the round non intermittent switch or the plug for the intermittent harness. In short, they sent you the wrong thing
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #8 of 16 Old 04-02-2011, 12:51 PM
John Strenk
John Strenk's Avatar
1976 CJ5
No, the delay wiper switch is much more complicated. THat is the right one for a replacement. dslywalker has a picture but it needs to be updated a little.
please excuse the picture, first time on a Linux editor...
John Strenk is offline
post #9 of 16 Old 04-02-2011, 11:05 PM
only in a jeep cj
Wow, then I stand both corrected and amazed at the crap they pass off as a replacement switch.
Ed
1975 CJ-6 1983 CJ-8
post #10 of 16 Old 04-04-2011, 08:31 AM
John Strenk
1976 CJ5
Kinda Like DSDD instead of SSDD when it comes to replacement parts. At least they are still making some replacement parts. .
post #11 of 16 Old 09-17-2012, 06:32 PM
DENVAR03
JOHN
me again!!!!.i thought i was done with wiring,and closed up my dash,now my wiper switch is DEAD!!!!!.I have power,to dark blue wire,and on red/wht.trace wire,with key on.On harness,to motor,when plugged in,i have power always,to white coming in,and black going to motor.wiper motor ,will not run!!!!!,if i push in on knob,i hear washer motor run.what could be wrong????
thanks dennis
DENVAR03 is offline
post #12 of 16 Old 09-18-2012, 12:45 PM
John Strenk
1976 CJ5
Did you check the ground to the case? I ran a extra wire for my ground...
post #13 of 16 Old 09-18-2012, 02:40 PM
DENVAR03
john
the motor is lying on jeep floor,maybe that is it,should i just ground motor,i think switch is grounded in dash.my old switch,had a white ground wire,this one does not.
dennis
DENVAR03 is offline
post #14 of 16 Old 09-18-2012, 06:55 PM
DENVAR03
JOHN
I JUST SPENT AN HR.,TRYING TO GET WIPERS GOING,GROUNDED MOTOR TO DASH TO TEST,AS MY WINDSHIELD IS NOT IN YET.HERE IS WHAT I HAVE,PLUG GOING TO W/MOTOR,4 WIRES,WHT. BLK ORAN.,AND GREY,FROM,FROM LEFT TO RIGHT.FROM MAIN HARNESS .FROM MOTOR LEFT TO RIGHT,IS RED, BLUE ,GREEN ,BLK.I HAVE POWER WITH KEY ON,AT BLK. AND GREY,FROM MAIN HARNESS.I HAVE POWER TO MOTOR,FROM MOTOR HARNESS,AT RED,AND BLK WIRES.NOTHING WITH KEY OFF.WHEN I GROUNDED MOTOR TO DASH,IT GOT REALLY HOT!!!!,SO I DISCONNECTED IT ,AND STOPPED.I,
DENNIS READ SOMEWHERE ON FORUM,THAT MAYBE WIRES MIGHT BE REVERSED FROM FACTORY.DO MY COLORS MATCH ,WHAT IS NEEDED????
DENNIS
DENVAR03 is offline
post #15 of 16 Old 05-19-2013, 11:25 AM
rsegriggy
1981 CJ7
Bump from a while ago, but seems relevant:
I just installed the omix-ada switch pictured above. For the first time in the 16 years I've had the jeep, the washer works from the wiper/washer switch. Woo hoo
EXCEPT - the washer pumps turns on briefly each time I move the wipers from off to low, low to hi, and back down as well. Basically, it very briefly activated the washer at each detent on the switch. Do all the replacement switches do this or is mine on the verge of failure? It also seems to turn on the washer at the slightest push of the switch. Anyone see similar behavior?
rsegriggy is offline
81 Wiper Switch reef2003 Jeep CJ Forum 2 01-06-2011 04:24 PM
wiper switch wrongway92407 Jeep CJ Forum 2 01-09-2010 08:43 PM
Ford Wiper Switch wiring to Jeep Wiper Motor Exposed Jeep CJ Forum 1 01-23-2009 08:45 PM
Wiper Switch powermacj7 Jeep CJ Forum 6 12-21-2008 09:10 PM
Help with wiper switch jeeperscrepers Jeep CJ Forum 5 12-16-2008 11:12 AM
