Wiper fluid? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Wiper fluid?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 09-12-2014, 02:26 PM   #1
chrisdj1992
Wiper fluid?
Something I've been wondering about I noticed that next to my coolant reservoir there is another labeled wiper fluid. Was there a motor for this that came stock? Where would the fluid spray from?
chrisdj1992 is offline   Reply With Quote
Unread 09-12-2014, 02:33 PM   #2
HackFabrication
1976 CJ5
Pump is in the bottom of the tank. Fluid sprays from a two headed nozzle on the cowl.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Unread 09-12-2014, 04:44 PM   #3
LumpyGrits
Don't use 'tap' water in the tank.
Use distilled, only.
Same for your cooling system--
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 09-13-2014, 10:58 AM   #4
Dborns
1983 CJ7
You can get a new motor from an auto parts store. You'll also need the tubing that goes up to a "Y" that then feeds the nozzles on the cowl.
Dborns is offline   Reply With Quote
Unread 09-13-2014, 12:22 PM   #5
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
There is no Y on a CJ7. Only a single nozzle with 2 outlets to spray on the windshield. If you have a YJ tub and didn't convert, it may have 2 outlets.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote
Unread 09-13-2014, 12:45 PM   #6
Dborns
1983 CJ7
Yep, youre right! My old CJ had the single nozzle in the middle of the cowl, and my current YJ tub is different. Sorry for the incorrect info!
Unread 09-13-2014, 05:15 PM   #7
chrisdj1992
Does anybody have a picture. Also were would the control switch go on the dash
Unread 09-13-2014, 05:32 PM   #8
LumpyGrits
The control switch, is part of the the OEM wiper switch on my '85.
LG
Unread 09-13-2014, 05:33 PM   #9
waterdowg
The control is part of the wiper knob. Just push it in.
waterdowg is offline   Reply With Quote
Unread 09-13-2014, 07:33 PM   #10
hp_lovecraft
1981 CJ5
My switch failed last year, and had to replace it with a Crown. Its a flimsy piece of crap. Its loose and rattles.
But thats just the adventure of owning a Jeep. and I figured I'd replace the the rubber tubing, since it was cracked and leaking....... but could not reach the tubing behind the firewall, no matter how much I contorted.
SO then I drilled holes into the hood and installed those generic plastic sprayers from the parts store. lol.
hp_lovecraft is offline   Reply With Quote
Unread 09-14-2014, 01:32 AM   #11
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's the OEM style spray nozzle.
The pump is activated by pushing in on the wiper control knob.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 09-14-2014, 11:39 AM   #12
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Be to use only synthetic washer fluid, especially if your Jeep has a T5.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote
Unread 09-14-2014, 11:47 AM   #13
chrisdj1992
Originally Posted by Matt1981CJ7
Here's the OEM style spray nozzle. The pump is activated by pushing in on the wiper control knob. Matt
I always wondered what that was. Thank you for that.
Unread 09-14-2014, 11:48 AM   #14
chrisdj1992
Thank you I do have a t5 now just out of curiosity how does the washer fluid affect the transmission
Unread 09-14-2014, 12:16 PM   #15
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
While you are at it, don't forget to change the blinker fluid too! ;-)
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
