Quantcast winter driving with no top. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > winter driving with no top.
Old 11-18-2007, 08:01 PM   #1
48 willys
1968 CJ5
does anyone use there cj in the winter without a top ? I ride a snowmobile all winter and can't see driving open top can be any colder. parked in a heated shop at night so no snow getting inside it. ( driving in southern states doesn't count )
48 willys is offline   Reply With Quote
Old 11-18-2007, 08:12 PM   #2
thiswebs4u
I do, just leave the bikini top on and park it in the garage. Last winter in 3 feet of snow I had a blast.
1979 CJ-7, Chevy 350, edelbrock 600 cfm, mild rv cam, T18A, D30 front D44 back (locked).
2004 Grand Cherokee Limited.
2004 PSD Superduty 4x4 supercab shortbed.
thiswebs4u is offline   Reply With Quote
Old 11-18-2007, 09:27 PM   #3
high51977
I used to plow with no top on my 57 and plan to do the same this year with my 77
Play by the rules you're gonna miss all the fun
high51977 is offline   Reply With Quote
Old 11-18-2007, 10:13 PM   #4
SuB8HaVeN
Shoot, it starts hitting under 60 degrees down here in Florida and I went out and bought a hardtop and full steel doors. Go figger...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 11-18-2007, 11:44 PM   #5
bjf498
1983 CJ7
I run mine with no top or doors some times when its around 35*
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline   Reply With Quote
Old 11-19-2007, 12:15 AM   #6
tahoe wheelers
I havent had mine on yet, and I hunted in the snow with it one weekend. I did freeze my buns off one morning before sunrise for about an hour on the hwy and that really sucked. If you have full hard doors and a bikini top you should stay fairly warm as theres not direct wind on you and the heat from the heater seems to keep me decently warm.
However, I will get my top on only when I get my used winshield frame to mount up flush with my front driver side door. About a half inch gap in between the door and the windshield.
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
www.therockgods.com
www.reno4x4.com
tahoe wheelers is offline   Reply With Quote
Old 11-21-2007, 04:50 AM   #7
solitudetree
I run a bikini top with windbreaker and just put on brand new doors. Once I get rid of this persistent cough, the doors will come off unless it gets really cold. I do have a decent heater due to the chevy blower motor upgrade.
[COLOR=DarkGreen][FONT=Century Gothic]All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
[/FONT][/COLOR]
solitudetree is offline   Reply With Quote
Old 11-21-2007, 05:52 AM   #8
Oily
Yes it does . I work outside twelve hours a day sometimes all night. It gets cold and worse, wet and cold. I dress to defeat it.
I have a hard top but do not always use it. You can not have a hard top and a bikini top, mounting problems. I drive often topless. Rain, cold, I don't care.
Oily is offline   Reply With Quote
Old 11-21-2007, 07:47 AM   #9
badron
CJX made a hard tops? Yea it's called a Cherokee. Got one myself when number one rug rat was born. Sweet ride but it's no CJ.
badron is offline   Reply With Quote
Old 11-21-2007, 08:50 AM   #10
TOBYWON
Well Sub, I'll, be the crazy dude in Tampa driving around in <45 degrees topless then! I love it! MY wife and kids freeze...but hey, the Jeep gets better gas mileage anyway, when they follow behind me in the Nitro!
"... God demonstrates his own love for us in this: While we were still sinners, Christ died for us." Rom 5:8 (NIV)
/l , [____],
l---L--OlllllllO-
()_) ()_)----)_)
TOBYWON is offline   Reply With Quote
Old 11-21-2007, 08:52 AM   #11
aero mech
aero mech's Avatar
1980 CJ7
I rode with a bikini top and hard doors for two winters. Our winters aren't that extreme here in MS. Wasn't bad with a good coat. I even have a hard top but couldn't find time to reinstall it. JC
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline   Reply With Quote
Old 11-21-2007, 08:53 AM   #12
Rubi22
x2. That damn sun is too harsh for me in the summer, so I leave the top up until about mid-October. That's the perfect time for topless driving... the soft-top, that is.
Rubi22 is offline   Reply With Quote
Old 11-21-2007, 12:06 PM   #13
JeepHammer
Running On Empty...
1973 CJ5
Nothing like a set of 'Off Road' chains in snow!
I leave the bikini top on and get out my Carhart coveralls, attach the snow blade, and make things work...
We haven't had a snow in a while that required a snow blade, but when it does snow, We get the chains out and go have some fun!
JeepHammer is offline   Reply With Quote
Old 11-21-2007, 04:38 PM   #14
slacker92104
It helps a bunch to pt on the full soft doors with a bikini. I guess it's cheating a little, but is a hell of a lot easier than putting the full top on when it's cold.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline   Reply With Quote
Old 11-22-2007, 01:09 PM   #15
Uncle Russ
Life is better lived topless!
Russ
“When you're swervin' on life's highway, you're runnin' someone off the road."
-- Robert Earl Keen
Military Jeepers Click Here!
Uncle Russ is offline   Reply With Quote
Glock Forum
