Winshield grab handle mount - JeepForum.com
post #1 of 8 Old 11-22-2013, 01:10 AM Thread Starter
mattp1788
Have a set of jk grab handles that I want to mount on the windshield frame but when I drilled self tapping screws in the frame they just came out since the frame isn't very thick. Does anyone have any suggestions on how else I can mount these handles to the windshield frame?
mattp1788 is offline
post #2 of 8 Old 11-22-2013, 04:56 AM
Shenandoah
With the thin metal, pulling on the handles is gonna rip them out. You could try nutserts, but any force on the handle is still gonna pull it loose.
Turn a wrench, save a tree
Shenandoah is offline
post #3 of 8 Old 11-22-2013, 08:16 AM
WindKnot
1977 CJ7
I worry that with the foldable windshield of a CJ, you might end up "warping" it when it's unsupported by a hard top. Even with a soft top I wonder if THAT is enough support for someone to put their weight into a grab handle.
If you go forward with this idea you may want to put that handle as low as practicable. Personally, I'd reconsider.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 8 Old 11-22-2013, 08:28 AM
scottg73
1979 CJ5
If your self-tapping screws pull out then you're using the wrong type for the job.
For thin metal you need a short fat screw that we usually called a 'stitch screw' or 'lap screw' when I put up metal buildings ...a regular self tapping screw will generally not grab or strip easily in thinner metal.
scottg73 is offline
post #5 of 8 Old 11-22-2013, 08:31 AM
scottg73
1979 CJ5
Something like this.
scottg73 is offline
post #6 of 8 Old 11-22-2013, 03:19 PM Thread Starter
mattp1788
Thanks guys for the info... My ultimate goal is to be able to put spreader bars across from the windshield to the roll bar and just put a grab handle there but can't seem to find just spreader bars. Or find a complete tj roll bar and put it in!
post #7 of 8 Old 11-25-2013, 05:28 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
There are several sets on ePay right now.
2Xtreme is offline
post #8 of 8 Old 11-25-2013, 06:22 AM
82JeepCJ7
1982 CJ7
Put a full cage in and build grab handles into the cage. Kill 2 birds with one stone.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
