Windshield wipers problems and YJ frame -
Go Back > Models > Jeep CJ Forum > Windshield wipers problems and YJ frame
FS: Wranger BRIGHT License Plate LED! Just $3! Great value6th annual beat your wife to the credit cards sale!!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 10-29-2015, 08:18 AM   #1
1979 CJ7
I have a YJ windshield frame swapped on my CJ7 and I am having trouble with my wipers getting stuck. They worked fine for years.
Now there is enough play in the linkages that I can move the wipers 5" or so back and forth by had with them turned off. They work just fine until I pass a semi or the wind gusts just right on the highway. Then the drivers side wiper will get pushed too far the passenger side and the system gets jammed up. I believe that oblong groove that I found at the linkage connection is the problem.
I didn't do this swap so I'm trying to figure out what the PO did make this work.
Since I have a YJ frame, do I need YJ linkages?
The motor arm link from what I can find is 11" for a YJ and 10 1/8" for CJ's but is the longer arm different as well? I ask because I can't seem to find that one for a YJ but can for CJ's.
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2015, 08:49 AM   #2
Had the same problem with my wipers, the drivers side wiper would jam up everything. I found it to be the wiper linkage pivot(I think thats the name of the part)
I replaced both of them working fine
nmJEEPcj is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
