Windshield Leaks - JeepForum.com
post #1 of 8 Old 03-04-2002, 07:56 PM Thread Starter
CJ7Jeff
Question Windshield Leaks
Okay, here is the problem. My windshield leaks around the gasket when I drive at highway speeds in the rain. I am guessing that it is the outer edge of the gasket that needs to be sealed. Has anyone else run into this problem? If so how did you go about fixing it, or did you? I am thinking that running a bead of clear silicone around the outer edge of the gasket should fix it.
Thanks,
Jeff
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #2 of 8 Old 03-04-2002, 08:23 PM
HighCountry
Question
Hmmmm.... Is there RUST under the gasket? If I were you, I would be very interested in seeing what is being hidden by the gasket. This would be a GREAT time to install a new windshield and gasket. They are very inexpensive... Collins Brothers Jeep had the glass for about $78 last week!
Bruce
HighCountry is offline
post #3 of 8 Old 03-05-2002, 11:49 AM Thread Starter
CJ7Jeff
Post
It's not rusty. I just replaced the frame last year. Made sure I had it painted up right by a body shop before I had the glass installed. I am thinking that they don't seal the gasket to the frame. I think they seal it to the glass but then they just pop it into the frame. My buddy has an 83 and it does the same thing.
Thanks
CJ7Jeff is offline
post #4 of 8 Old 03-05-2002, 01:49 PM
scrambler24
Post
I just had my glass replaced to pass inspection and you're right, its all a snap together process for a jeep. so there is no liquid seal like most cars. The PO of my jeep had a bead of silicone all the way around the factory rubber and it didn't leak then, does now with new glass and rubber. So I guess I will repeat the silicone process
my .02
Jeff
"full of useless knowledge and it shows"
scrambler24 is offline
post #5 of 8 Old 03-08-2002, 08:37 PM
K5QM
Post
Thanks,
Jeff
K5QM is offline
post #6 of 8 Old 03-08-2002, 08:45 PM
K5QM
Post
Jeff I had the same problem with my '86 CJ-7. I removed the windshield and applied windshield sealant (that you can get at any good auto parts store)to the both groves and no more leaks. Apply a small bead, about 1/8'. It will spread. If your paint is good a little 3M adhesive remover will remove any extra adsesive without any damage to the paint.
Jerry
K5QM is offline
post #7 of 8 Old 03-13-2002, 08:44 PM
tholmes3
Post
I have used a sealant, kind of like caulk that is flexible, yet adhesive and is waterproof. I have used it on many things from rusted out roofs, hols in metal, and various other products. Another good thing is that it usually comes in a variety of colors, to lessen visibility. Gasket sealer might seem like an obvious choice, but the down side to that is it gets rock hard, though waterproof, but is hard as hell to correct a mistake with it and ro replace anything connected to it---> forget it!!!!
T3
tholmes3 is offline
post #8 of 8 Old 03-14-2002, 04:58 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
Hell, I was gonna tell you all the same things! LOL
Just use a good silicone around the outer edge of the gasket, smoothing it with your finger, its not much of a gap, so go very lightly.
4wheeler4CJ is offline
Help with leaks? newjeepowner Jeep CJ Forum 4 04-04-2009 01:50 PM
Windshield Compatibility - CJ7 windshield to replace a '76+ CJ5 frame? kbazurpe Jeep CJ Forum 3 08-30-2008 09:02 PM
CJ7: Oil leaks, vacuum leaks and suspension squeaks ghengis86 Jeep CJ Forum 0 04-17-2008 08:30 PM
leaks M79 Jeep CJ Forum 3 07-06-2007 08:57 AM
leaks 1976cj7 Jeep CJ Forum 8 04-15-2007 07:24 PM
