Windshield frame hinge nuts broken. - JeepForum.com
post #1 of 3 Old 05-17-2013, 01:37 PM Thread Starter
Alex77cj7
1977 CJ7
I bought a windshield frame from a guy and he had a hinge on it. While removing the hinge I noticed that some of the nuts that mount inside are broken off and missing. On the passenger side there is only one but that is still there and on the drivers side all the nuts are there but there's a bolt broken off in one.
Any ideas of what I can do to fix this?
Thanks,
Alex
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
post #2 of 3 Old 05-17-2013, 01:41 PM
Davis77Cj
1977 CJ7
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #3 of 3 Old 05-17-2013, 03:18 PM
hp_lovecraft
1981 CJ5
I had the same problem. Some of my windshield hinge nuts were stripped. When I researched the issue, a common solution was to drill out the nut, and use simple nutserts. Others would cut off the entire corner to access the inside, so that the bad nuts could be removed, and new nuts welded on.
I used a different approach. I tilted the windshield forward so that I could drill a hole just below were the hinge nuts were located. The hole was just big enough so that I could insert a new not ON TOP of the bad nut using some needlenose plyers. Then simply used a longer hinge bolt. It works, and only required minimal effort
hp_lovecraft is offline
