Windshield Cowl weather strip leak - JeepForum.com
post #1 of 6 Old 05-09-2013, 12:43 PM Thread Starter
modzeldp
1976 CJ7
I've noticed that water gets in under the seal between the windshield frame and the body(cowl). I replaced the seal and still had the problem. Then What I found was that the fiberglass body is sagging in the middle, so if you are to lay a straight edge across from one side to the other it has settled/sagged about 3/8" in the center. I'm thinking of ripping the dash all apart to install some type of reinforcement channel under the fiberglass. Has anyone else ran across a similar problem? If so what did you do to fix it?
modzeldp is offline
post #2 of 6 Old 05-09-2013, 01:09 PM
vinnyabs
1983 CJ7
Can't speak as to a fiberglass tub, but on my steel tub I threw a 3/4" door foam weather strip on the cowl side and haven't looked back since.
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #3 of 6 Old 01-15-2015, 01:16 PM Thread Starter
modzeldp
1976 CJ7
I finally got around to it, installed a channel under the bodt that spans from one windshield hinge across to the other and supports the center. Sag is gone, and now the leaks are sealed.
modzeldp is offline
post #4 of 6 Old 01-16-2015, 05:50 PM
S76
Take a look at posts 366 to 370
http://www.jeepforum.com/forum/f8/st...2/index25.html
Mine wasn't sagging but I wanted to make sure it didn't.
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #5 of 6 Old 01-16-2015, 09:04 PM
orange150
1982 CJ8
Do you mean you replaced the OEM style gasket with some 3/4" single sided foam?
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #6 of 6 Old 01-18-2015, 08:38 PM
jammer1
1979 CJ7
I've heard of this from other owners of fiberglass tubs. On my cj7 (fiberglass) it always leaked. When I rebuilt her I put a straight edge and it sagged about 1/8". I built it up with body filler when I did the body. That and a new seal and it hasn't leaked since. The cj8 I'm building now has a metal tub and it sagged less than 1/8" which I built up with filler also. The gasket usually doesn't seal this (I'm guessing because the gasket is so stiff) so you have to build it up with something.
jammer1 is offline
cowl , leak , windshield
