Windshield brackets - JeepForum.com
post #1 of 14 Old 03-05-2016, 01:27 PM Thread Starter
eddie_helm
Windshield brackets
The brackets that it came with don't work. The force the windshield to sit at the wrong angle even after adjusting the hinges, doors, and these brackets it still doesn't come close to the right angle. These also sit crooked when mounted so I'm wondering if they weren't diy by the PO. Also since the windshield sat at the wrong angle for so long the seal along the bottom doesn't mate up well and I'm assuming it'll let water in if I drive in the rain
eddie_helm is offline
post #2 of 14 Old 03-05-2016, 01:28 PM Thread Starter
eddie_helm
Can someone give me a measurement center to center from the dash mount and the mounts to windshield to see if I just need new mounts or if something wonky is going on with my windshield
post #3 of 14 Old 03-05-2016, 02:06 PM
bob4703
1974 CJ5
Eddie fill out your profile so we can tell what you are working on. I could give you measurements that might not apply to your Jeep.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #4 of 14 Old 03-05-2016, 03:34 PM Thread Starter
eddie_helm
It's a 78 CJ5.
post #5 of 14 Old 03-05-2016, 04:10 PM
jeepwhore
Stock ones weren't chrome plated and I can't see anyone paying to do that to home made ones. They are probably Kentrol or some other aftermarket......and if they are anything like the aftermarket hinges, don't follow the oem dimensions all that well.
Do those make the windshield sit too far back or too upright?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #6 of 14 Old 03-05-2016, 04:15 PM Thread Starter
eddie_helm
It makes it sit too far back.
post #7 of 14 Old 03-05-2016, 04:27 PM
orange150
1982 CJ8
Can you share some more pictures of the windshield frame and how it's sitting?
Sent from my iPhone using Tapatalk
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #8 of 14 Old 03-05-2016, 06:23 PM
texasdave
texasdave's Avatar
1980 CJ7
^^ He has pictures in his thread I'm in over my head.
texasdave is offline
post #9 of 14 Old 03-05-2016, 07:57 PM
Chrisinchwk
1982 CJ7
Perhaps it's not an original windshield?? YJ maybe?
Chris
Chrisinchwk is offline
post #10 of 14 Old 03-05-2016, 08:01 PM
jeepwhore
That shouldn't matter, both are the same dimensionally and should sit at the right angle (although the plates need to be slightly modified to use a YJ frame) I'm thinking either the holes in the plates are incorrect or the frame has been bent where the plates attach.
post #11 of 14 Old 03-07-2016, 07:10 AM Thread Starter
eddie_helm
I set my doors and then measures from the windshield to back of the tub 67.5" and everything seemed to line up. The brackets were a 1/2 inch out from fitting so I just made some new holes and remounted them and everything works fine. Top went on nicely, doors seal and I'm one step closer to having her on the road. Part of the issue is the hinges weren't mounted right by the PO so eventually I'll have to address that but for now I'm satisfied
post #12 of 14 Old 03-07-2016, 08:20 AM
jeepwhore
post #13 of 14 Old 03-07-2016, 10:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Really tough to not mount the windshield hinges correctly but easy to bend them and then the windshield will not sit correctly. Or did he not use counter sunk bolts?
But if you have the door angle right and the measurement correct. A good hinge will fix everything else.
John Strenk is offline
post #14 of 14 Old 03-07-2016, 10:50 AM Thread Starter
eddie_helm
Originally Posted by John Strenk
Really tough to not mount the windshield hinges correctly but easy to bend them and then the windshield will not sit correctly. Or did he not use counter sunk bolts? But if you have the door angle right and the measurement correct. A good hinge will fix everything else.
The bottoms were mounted correctly but the tops were mounted wrong. They installed a plate for the bolts to thread to inside the frame but everything was installed with the windshield leaned all the way back against the dash pad. To fix it properly will be more work than its worth right now. Once I get it on the road and make sure I don't have any surprises with the drivetrain I'll come back to it. But for now it works.
