Willys Flat fenders on a CJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Willys Flat fenders on a CJ
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 03-06-2009, 06:43 AM   #1
BioTex
OIIIIO
BioTex's Avatar
Anyone done it? I am picking up a set of 1950 flatties this weekend, and am thinking once I get them home, I will hold them up and see how they fit. I might go with it. The metal is really about twice as thick as the newer ones, so should be easy to weld/fabricate a fit.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
Unread 03-06-2009, 07:04 AM   #2
Rollbar
1984 CJ8
That would be sweet, I would like to see this.
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote
Unread 03-06-2009, 07:24 AM   #3
duffer
1955 CJ3B
They fit entirely different than the CJ5/6 fenders, to the point where it would probably be less work to make new ones from scratch.
duffer is offline   Reply With Quote
Unread 03-06-2009, 09:33 AM   #4
ken78cj5
1978 CJ5
Checkout Gen-Right replacement fendsrs. They are a flat fender design, and you can order them in different flare widths
ken78cj5 is offline   Reply With Quote
