Yes and no. I installed a steering box, lower and upper columns from a YJ. They all fit fine. They all fit together. However, you cannot piecemeal the parts together. The interfaces do not match (box stub is different, as is upper column stub). I hope I'm not confusing you!
One thing I did previously was make a new shaft out of two. Upper shaft from Cj and lower shaft from yj. This was to fit a yj box to my cj column. I have since upgraded the column to the yj style. It worked well tho.
Moves the dimmer light to the dash instead of on the floor. Other than that I don't think there's much difference at all as far as functionality.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
