Will it work? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Will it work?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTJ 5.25" Speaker Adapters - NalinMFGJK Vent Covers - NalinMFG
Unread 09-10-2014, 05:58 PM   #1
SAVRICH
Will it work?
Will a 1980 cj7 hard top fit onto a 1985 cj7 with no modifications? Probably been asked but don't have the time to search for it
SAVRICH is offline   Reply With Quote
Unread 09-10-2014, 06:17 PM   #2
WindKnot
WindKnot's Avatar
1977 CJ7
You're 24 years old and have no time?
Paved roads are just for getting you to the starting point!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is online now   Reply With Quote
Unread 09-10-2014, 06:19 PM   #3
Rolandt03
1983 CJ7
You could have searched that and found and answer by the time you logged on and posted that question! Yes it will, you don't know much about cj7's do you?
Rolandt03 is offline   Reply With Quote
Unread 09-10-2014, 06:25 PM   #4
WindKnot
WindKnot's Avatar
1977 CJ7
There is some hardware to install and you may need to adjust the rake of the windshield frame. All not difficult to do.
But seriously...
Unread 09-10-2014, 09:09 PM   #5
SAVRICH
I had no time at the moment. I was driving and already logged on. Takes time to search threads for the answer. Thanks for the info though
Unread 09-10-2014, 11:38 PM   #6
82JeepCJ7
1982 CJ7
CJ7 tubs are all the same dimensionally...
The easiest way to get the top to fit correctly, is to loosen up the windshield frame, put the hard top on and make sure its lined up with the opening correctly, and the back corners of the tub. Once its all bolted down, then tighten down the windshield frame.
There is also this from the manual...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
