will a T90 bolt to a 258 6 - JeepForum.com
post #1 of 8 Old 05-20-2003, 10:05 AM Thread Starter
soler
Will a t90 bolt on a AMC 258 6 cyl? If not is there a kit ?
soler is offline
post #2 of 8 Old 05-20-2003, 10:30 AM
sampson9dk
sampson9dk is offline
post #3 of 8 Old 05-20-2003, 10:44 AM Thread Starter
soler
Ok
Ok. so with an adapter? I dont know anything about my 258 or a T90. Does Amc and the 134 4 cylinder have the same bellhousing?
soler is offline
post #4 of 8 Old 05-20-2003, 11:08 AM
CSP
Not even close. If they were the same a T90 would bolt up to a 258 without an adapter. An adapter is not made to bolt a T90 to an AMC engine. That link samson gave you at Novak was to bolt a T90 to a General Motors engine, specifically a Buick V6, Chevy V8 or I6.
Only the AMC staright sixes and V8's share the same bellhousing bolt pattern.
There are plenty of light duty, inexpensive three speeds out there that will bolt to the 258. The most widely used would be the T150. The T14 and T15 can also be used behind the 258.
CSP is offline
post #5 of 8 Old 05-20-2003, 11:36 AM Thread Starter
soler
what kit ?
There are two kits for the t90. I have a 258 out of a 1973 AMC Hornet. What kit will work?
soler is offline
post #6 of 8 Old 05-20-2003, 01:53 PM
CSP
Are you not paying attention???
Read the kit descriptions and what I just posted. Those kits are for General Motors engines, not AMC. There are no adapters made to adapt the T90 to any AMC engine. Your 258 is an AMC engine.
It can't be done unless you come up with your own adapter.
CSP is offline
post #7 of 8 Old 05-22-2003, 10:58 AM Thread Starter
soler
alright
OK Ok then what manual transmission will bolt on a 258 and then also allow a dana 18 to be used? T4 ? T5 ? give me setup info. THe only thing that I really cant change is the 6, because I already have one.
soler is offline
post #8 of 8 Old 05-27-2003, 11:14 AM
CSP
Any transmission that can be used with a Dana 20 can be used with a Dana 18 as long as it's the large hole version of the 18. I'm not going to list them out as the Novak link samson gave you has the answers. Do the research, it isn't that hard.
CSP is offline
need bolt size for v8 motor mount bolt to frame rcgkaw Jeep CJ Forum 3 08-25-2009 10:16 PM
Stock Shackle Lenghts (bolt to bolt) Acer Jeep CJ Forum 1 08-15-2006 05:39 AM
Dumb MC2100 adapter mounting bolt question-Which bolt goes where? hfjeff Jeep CJ Forum 19 09-17-2005 12:40 PM
Rear Yoke strap and bolt VS. U-Bolt???? HELP PLEASE! scottahicks Jeep CJ Forum 6 06-12-2004 12:30 AM
Need help with U-joint strap and bolt to U-bolt conversion hollywood Jeep CJ Forum 1 06-22-2003 03:15 PM
