Will stock sending units work with aftermarket gauges? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Will stock sending units work with aftermarket gauges?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 06-01-2009, 03:26 PM   #1
imtheant
I want to buy all electronic Autometer Phantom gauges for fuel, volt, temp and oil and was wondering if these will work with stock CJ sending units or do I have to replace all the units with new ones from Autometer. Any ideas?
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline   Reply With Quote
Unread 06-01-2009, 03:33 PM   #2
BioTex
For a fuel gauge, the sender ohms must be matched to the gauge. Volts is no problem, not sure about the rest.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
Unread 06-01-2009, 06:48 PM   #3
VACJ7
Hockey Rules!
VACJ7's Avatar
Like BioTex said, make sure the fuel gauge ohms match the sender. Easy to match. Oil and temp should come with their own sender. At least my Stuart Warner temp gauge did.
VACJ7 is offline   Reply With Quote
