Will a soft top and soft doors fit a slightly bent tub? - JeepForum.com
post #1 of 4 Old 04-14-2011, 10:16 AM Thread Starter
KenSC
1979 CJ7
Just throwing this out there to see what the general consensus is. I have a '79 CJ7 purchased a few months ago. It did not come with any doors, just a bikini top. I bought a nice hard top and hard doors and while struggling to get the hard door installed on the passenger side I finally realized my door opening is short about 3/4 inch at the top of the tub door opening. The driver side door will work, but the passenger side will not. I am not sure if the tub is bent or if somone did some work to that side incorrectly.
Question is: Do you think I can buy some soft doors and a soft top and manipulate the soft door on the passenger side to fit? Could I possibly cut out some of the frame on the soft door to make it work if I have to?
The other option I am looking at is taking it to a body shop and getting an estimate to fix it. Or I could just install a different tub.
KenSC is offline
post #2 of 4 Old 04-14-2011, 10:41 AM
MemphisCJ7
1983 CJ7
I have bestop two piece doors on an '83 CJ-7. They will adjust up and down to line up with your striker pin. That may or may not solve your problem. So if your striker pin is the correct hieght; it "should" work. Is there a local 4x4 shop around? Perhaps you could try some on. No CJ seems to be the same.
I do not have a top other than a windjammer and bikini top though. I enjoy the set up because it looks like a mini truck. Maybe that is an option for you if the top doesn't work out.
MemphisCJ7 is offline
post #3 of 4 Old 04-14-2011, 10:44 AM
waterdowg
Check the Windshield frame. It sound like the Passanger side frame is pulled back to far. Loosen wiindshied and adjust it forward. That may solve your problem. Or if you have the top off measure from the top corners of the windshield to the back of the jeep or the roll bar and see it the measurement is the same or different. If its the same its atub issue. If it different the windshield needs to be adjusted.
waterdowg is offline
post #4 of 4 Old 04-14-2011, 10:58 AM Thread Starter
KenSC
1979 CJ7
The door won't fit in the hole even with the windshield down. I loosened every bolt on the door hinges, and even took the bottom hinge off of the tub to make sure it wasn't in the way. When I measured from the top hinge on the tub to the top of my striker plate on the tub, the passenger side is 3/4 inch to 1 inch shorter than the driver's side. And when I flat out hold the door against the door cut out on the tub, it will not fit. The driver's side door will fit into the cutout on the driver's side.
KenSC is offline
$150 for soft top and full soft doors, is it worth it Matt_G Jeep CJ Forum 9 03-23-2010 05:56 PM
CJ Soft doors mgaither0 Jeep CJ Forum 4 09-23-2009 03:23 PM
Soft top doors won't stay shut - full soft doors Cutlass327 Jeep CJ Forum 0 05-18-2009 09:56 AM
Two Piece Soft Doors VS. Lower hard doors with soft upper halves JeepScrambler Jeep CJ Forum 6 10-27-2005 07:29 AM
looking for full soft top for CJ-8 & doors hard or soft tarponbooter Jeep CJ Forum 0 02-21-2002 02:28 PM
